Hi guys,
One of the seals on my caliper is leaking very slightly. It has been converted to O ring pistons/seals.
The leak appears to be coming from a damaged top seal, the one that fits over the piston and seats into the caliper.
My question, is this seal the same size in both lip seal kits and O ring kits? I have a spare lip seal kit and was going to use the one seal from that if it's the same size. I'm in th UK so I can't just go to a local parts store and the specialists only have the complete conversion kit or the same lip seal kit that I have.
If fluid is leaking from the "top seal", the one that fits over the piston and seats into the caliper, then the o-ring seal is leaking. That top seal is just a dust boot.
Of course it is! Must gave been having a brain freeze! New caliper on order, thanks.
