Fuel pump install help
Old Jun 9, 2018 | 01:31 PM
pwsusi's Avatar
pwsusi
Default Fuel pump install help
Installing a fuel pump in a '71. I couldn't get the bolts to line up properly and noticed it's because there's rod in the way and I can't push the pump in properly. What's the best way to get the pump in?
Thanks.
Old Jun 9, 2018 | 01:54 PM
gr8t73's Avatar
gr8t73
Remove the rod coat it with bearing grease and reinstall then install the fuel pump. Be sure to push the rod in as far as possible the grease will hold the rod in the upward position which will allow you to to install the fuel pump and start the bolts. Be sure the fuel pump arm is centered on the rod and tighten the fuel pump bolts evenly.
Old Jun 9, 2018 | 04:06 PM
ronarndt's Avatar
ronarndt
Thanks.
Fortunately you did not try to force it by tightening up on the bolts. Then you would have had a real problem when you cracked the pump casting. That rod is the actuator rod that rides on the camshaft to operate the fuel pump as it gives a push every time the cam revolves. As gr8t73 suggested, the grease is an old school trick that still works.
Old Jun 9, 2018 | 04:40 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
turn the engine slightly so the cam it rides on is at a low spot....
Old Jun 9, 2018 | 05:21 PM
blue427's Avatar
blue427
put the engine on #1 firing order,the rod will go further.
Old Jun 9, 2018 | 05:25 PM
theandies's Avatar
theandies
All above is correct. Even with the cam at it's low spot, which does make it easier to install fuel pump arm will need to be depressed a little so you'll feel a little spring tension when holding it against the block.
There is a bolt in the front of the block that you can take out and put a longer bolt in to hold the push rod in place while you install the pump. You don't need to crank it down just enough to keep the push rod from falling out. Just don't forget to put the short bolt back with a little thread sealant.
Old Jun 9, 2018 | 07:01 PM
pigfarmer's Avatar
pigfarmer
Thanks.
First use your finger and see if you can push that rod back up in the hole. It might have just slipped down. If you aren't already you might try this from underneath - it's a little easier to see.
If it does go back up far enough then turn the fuel pump slightly so you can get the arm in and touch the bottom of the rod with it to hold it up. It rides on the pump arm normally anyway. I used my finger to hold the rod in place temporarily while I stuck the arm in. Just turn it upright and seat it. Should go in pretty easy.
If the rod doesn't go back up in that hole far enough that's why these guys recommended bumping the engine until it does.
Good luck
Old Jun 10, 2018 | 05:11 PM
Cool95vette's Avatar
Cool95vette
Do this. It's the easiest way.
Old Jun 10, 2018 | 10:42 PM
croaker's Avatar
croaker
The bolt worked for me.
To Fuel pump install help
