Electrical experts.. car simply died while under power. Long post.
Thanks,
Rick
Be SURE to remove any rings on your fingers and your watch FIRST to prevent electrical shorts.
I'd tend to be looking at fusible links coming off the solenoid and then the firewall connectors. There are a number of main power wires passing through the firewall connectors a few times on an 82. Look for red, red/black and red/white wires.
I think a low cost dyi could be to cut off any suspected bad connector or battery terminal, go back an inch or so into the cable and install a new connector.
The acid smell- the battery is trying to filter the AC from the alternator-
The tach jumpimg-there's actually a filter from the factory to filter the AC.
And the ECU does not like AC.
Start the car up- put your meter on AC and see how much you have at the battery terminals -should be no more then .5V.
Richard
Yes- the ECM can get fried...every try plugging in a battery powered radio into a wall outlet?!!! IIRC GM wired the ECM directly to the battery - to help protect it. The battery not only starts you car but filters and stabilizes the voltage.
Richard
When you first start up the vette, have you checked the voltage at the battery. How about when the alternator started getting really hot?
Two for two with new batteries...and maybe the first one makes number three ?
The smell of acid ...either the Alt is overcharging DC- but more than likely you'd be burning some bulbs out (dash ones usually go first!) or what I think-putting out way too much AC voltage.
No doubt it's the alternator.
Richard
My mechanic will have fun with this one...
