which oil do you use
Old Oct 20, 2002 | 05:27 PM
LT1driver's Avatar
LT1driver
Default which oil do you use
don't know how to do the poll thing so what do you use: Quaker State, Penzoil, Castrol, Havoline, Valvoline, Kendall or ? By the way K-Mart has Penzoil for .99 on sale. :cheers:
Old Oct 20, 2002 | 05:29 PM
gdh's Avatar
gdh
Default Re: which oil do you use (LT1driver)
Pennzoil as it was so highly recommended by MountainMotor - that was all I needed as this man sure knows his stuff. :yesnod:
Old Oct 20, 2002 | 05:58 PM
Paul L's Avatar
Paul L
Old Oct 20, 2002 | 07:47 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: which oil do you use (paul79)
10W60, why? Because Shell sponsors me with the lube :)
Old Oct 20, 2002 | 08:11 PM
Wrecked82's Avatar
Wrecked82
Default Re: which oil do you use (Twinnie)
60W? In the Netherlands?
Old Oct 20, 2002 | 08:15 PM
Ryan77's Avatar
Ryan77
Default Re: which oil do you use (Larry82)
Valvoline Max Life (engines over 75,000 miles) 10W-30 with a Mobil 1 oil filter.
Old Oct 20, 2002 | 08:36 PM
Twin_Turbo's Avatar
Twin_Turbo
Old Oct 20, 2002 | 08:38 PM
loose nut's Avatar
loose nut
I use castrol gtx or valvoline . I think that for long engine life under hard
conditions that the most important thing is how often the oil is changed.
I change mine every 2500 miles , but I am very hard on my motor and I
like to play near redline.
Old Oct 20, 2002 | 09:14 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
Default Re: which oil do you use (79L82hatch)
Mobil 1
Old Oct 20, 2002 | 09:16 PM
Binnie77's Avatar
Binnie77
Penzoil
Old Oct 20, 2002 | 09:38 PM
Brett K's Avatar
Brett K
I use Castrol Synthetic blend in my daily driver and have used Castrol in all my vehicles for quite a while with not a single engine problem ever. I will be using Castrol in the vette when it is done too.
Old Oct 20, 2002 | 09:45 PM
L48Shark's Avatar
L48Shark
From: If you can read this, thank a teacher. If it is in English, thank a veteran.
Cruise-In IV Veteran
Cruise-In V Veteran
I use Castrol GTX 10W-30. I thought about switching to a synthetic blend, but people told me it would make my engine leak (worse :lol:). 5 quarts go in and 3,000 miles later 4 quarts come out. :crazy:
Old Oct 20, 2002 | 09:48 PM
StrayDog's Avatar
StrayDog
Veteran: Marine Corps
moble 1 >>>, 10/30 In my 66 big/block & 5/30 in my C5. Works for me. :seeya
Old Oct 20, 2002 | 09:55 PM
Red73's Avatar
Red73
Default Re: which oil do you use (StrayDog)
Mobil 1
[Modified by Red73, 8:56 PM 10/20/2002]
Old Oct 20, 2002 | 10:17 PM
SLICKMAN's Avatar
SLICKMAN
There has been ALLOT of posts on just this subject and the hipe over oil brands is BS.. I use just about any 10w-40 that is on sale however, I do use the best filter I can get my hands on like Mobil 1 if I can find it. If you change your oil every 3,000 miles, the brand of oil you use is not important. I have been doing this for years and NEVER had problems, my every day cars last for close to 200,000 miles!! :yesnod:
[Modified by SLICKMAN, 9:18 PM 10/20/2002]
Old Oct 20, 2002 | 10:52 PM
SharkAttack's Avatar
SharkAttack
Daily Drivers: Royal Purple synthetic 10W-30
Corvette: Castrol 10W-40
Old Oct 20, 2002 | 11:48 PM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
In my '98...Mobil 1... 'cause that's what it recommends.
In my '72...Mobil 1... 'cause it works so good in my '98
In my '02 Monte Carlo SS...Mobil 1...see above two reasons :)
Dep
To which oil do you use
Old Oct 20, 2002 | 11:51 PM
73 LS-4's Avatar
73 LS-4
Red Line 10w40, nothing but the best for my girl :D Mobil 1 filters
:cheers:
Pat Kunz
Old Oct 21, 2002 | 12:17 AM
ry's Avatar
ry
marvel mystery oil!! :D :D :D :D :D :D
Old Oct 21, 2002 | 01:21 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
PENNZOIL HD30
