What is the strange sound? Could be a weak ground.
When I got my car years ago the horn wasn't very loud and didn't sound right. I took it off and found a screw on the body of the horn. I messed around with that and got it a lot louder and the tone sounded right after playing with this screw.
Here is a good article that may help.
A dodgy ground means it won’t pass enough current, muting the sound, or as above, the horn might be dodgy. Try it across a battery, see if it sounds better, to rule out the horn itself.
2016 C3 of Year Finalist
If you have mud wasps they could just be plugged. Try spraying a cleaner up into the mouth of the horn and rap on it with a screw driver handle. Repeat until the crap stops falling out
