HEI upgrades spark plugs
Old Jun 23, 2018 | 02:35 PM
pauls71stingray's Avatar
pauls71stingray
Default HEI upgrades spark plugs
Those of you that have upgraded a points distributor to electronic, did you use stock plugs and gap? Or did you increase the gap or use different plugs?
Old Jun 23, 2018 | 04:20 PM
sug's Avatar
sug
2020 Corvette of the Year Finalist (stock)
C3 of Year Winner (stock) 2019
I use the stock plugs and gap in my case they are A C r44n
Old Jun 23, 2018 | 05:09 PM
keithl1967's Avatar
keithl1967
If you are going from points to HEI, I would look for plugs that are intended for the later years ('74-up) for the C3 that came with HEI, and gap them according to the '74 and up specs...
Old Jun 23, 2018 | 06:32 PM
HeadsU.P.'s Avatar
HeadsU.P.
From 0.035 to the new HEI 0.045 gap.
Better spark, better flame, better burn, better better.
Old Jun 23, 2018 | 10:37 PM
stingr69's Avatar
stingr69
The big gaps are for factory lean emission engines. You don't need those big gaps if you are modifying the engine.
Old Jun 23, 2018 | 11:56 PM
NICE-7D3's Avatar
NICE-7D3
Default What plug should I use?
So what gap would you recommend for 350 base 190 hp on 73 if I go HEI, AND which plug if stock were AC 44RT
Old Jun 24, 2018 | 12:33 AM
Gunfighter13's Avatar
Gunfighter13
One step cooler heat range on the spark plugs gaped at .035.
Old Jun 24, 2018 | 09:41 AM
stingr69's Avatar
stingr69
Autolite park plugs to fit the heads with .035" gap and standard heat range to start. Then play with heat range if required. Autolite seem to have a broader heat range to stay clean.
Old Jun 24, 2018 | 10:10 AM
HeadsU.P.'s Avatar
HeadsU.P.
The bigger gaps came into play when the coils went from 20,000 volts to 50,000 V. Which is what HEI did for the automotive industry.
Old Jun 24, 2018 | 08:02 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
The bigger gaps came into play to minimize misfires when the leaner mixtures were used to lower tailpipe emissions. The HEI system is a higher energy (the E in HEI), not higher voltage, system to promote a longer spark duration to light off the lean mixture, and also allow for longer plug life to meet the federal emission system durability requirements. The coil output voltage didn't change significantly, as the lower compression ratio engines of that era didn't produce much cylinder pressure. (The plug gap size and cylinder pressure combination is the primary determinant of what the coil output voltage ends up being. 50 kV is a coil insulation rating, and not an indication of what voltage or energy the coil will actually put out.)
Old Jun 24, 2018 | 10:07 PM
CanadaGrant's Avatar
CanadaGrant
Also, the OP said he was converting to electronic ignition but didn't say HEI. If you are changing over to something like Pertronix stick with the stock plug gap. There is no performance benefit to increasing gap in either situation.
Old Jun 25, 2018 | 12:43 AM
Gunfighter13
The title says:
Old Jun 25, 2018 | 12:47 AM
CanadaGrant
Originally Posted by Gunfighter13
The title says:
You are correct. I read the post but forgot the title. My mistake but as said, increasing the plug gap is not going to do anything to improve performance.
To HEI upgrades spark plugs
