MSD mech advance spring combo?
Old Jun 29, 2018 | 05:51 PM
Sidneyhop454's Avatar
Sidneyhop454
Default MSD mech advance spring combo?
Im having an odd issue. Seems my mech advance is coming nearly all in at 900 rpm idle. Im using the two blue springs. Any recommendations?
Old Jun 29, 2018 | 07:53 PM
Sidneyhop454
I figured it out. Seems the distributor I just bought has a sticky mechanical advance. Even with the heavy springs on it doesn't completely retract to its start position.
Old Jun 29, 2018 | 07:57 PM
OldCarBum's Avatar
OldCarBum
The speed shop I'm working with said that the MSD's seem to work best using one silver and one blue spring on the mechancial advance.
But that is for my BB, not sure what you are running.
Old Jun 29, 2018 | 09:35 PM
cv67's Avatar
cv67
St. Jude Donor '05
Couldnt get any of those combos to givea decent curve finally gave in and took it to an old timer with a Sun machine.
Arent blue the weakest springs or was it silver?
Old Jun 30, 2018 | 12:52 AM
OldCarBum's Avatar
OldCarBum
I think silver is the weakest, at least I think that's what they told me.
They said to double check the setup instructions included in the box.
Old Jun 30, 2018 | 11:05 AM
A8skyhawk's Avatar
A8skyhawk
The MSD distributor instructions include graphical depictions of the mechanical advance curves (advance vs RPM) for the various spring combinations.
Old Jun 30, 2018 | 04:45 PM
theandies's Avatar
theandies
Here are the MSD spring values. I just happen to have my distributor instruction right next to my computer:
Heavy Silver
Light Blue
Light Silver
According to the instructions here are the possible curves:
2 heavy silver - slowest
1 heavy silver 1 light blue - next slowest
1 heavy silver 1 light silver - a little faster than above
2 light blues - getting a little faster
1 light silver 1 light blue - faster
2 light silver - fastest
Also the MSD stop bushing size and amount of advance they give:
Red - Smallest - 28 degree
Silver - 25 degree
Blue - 21 degree
Black - Largest - 18 degree
Hope this helps. If needed I can scan and post the curve charts for each combo. Just let me know.
Old Jun 30, 2018 | 08:11 PM
HeadsU.P.'s Avatar
HeadsU.P.
Four out of five dentist recommend: 1 light-blue spring, 1-light-silver spring.
Keep in mind those color coded stop bushings will only fit the MSD Billet unit and not the Streetfire for some reason.
To MSD mech advance spring combo?
