From all my research i have the plastic inside busted, i can hear it trying to raise! my question is how can i just stop it all together? i like the look of it down and don’t use the radio. thanks in advance!
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
I take it you do not have the CB antenna option? You can remove the assembly from the car and take it apart to lower it or just repair it with a new cable which is usually what breaks. Not a hard task either way. If you have the CB option, it is a bit more problematic to fix if the antenna load is broken which just happens to be an integral part of the antenna to make it go up and down and the CB attenuation adjustment. Good luck
I don’t think it has the cb option. I don’t really want it fixed just want the thing to stop squacking laugh out loud. its a aftermarket radio. ty for your reply
This forum is about fixing our beloved hobby cars as Buccaneer offered. If you are a C3 flipper or dealer, you're probably on your own.
If you're into restoring your own beauty It will involve an affordable $35 nylon antenna kit/instructions and a couple hours of your or your Technician's time to bring it back to life. Otherwise, unscrew the left (drivers side) speaker plate and reach behind to unplug the power connector until you have the $35 and time.
I will be more than happy to answer your question. To disable your power antenna, simply unplug the power antenna relay shown in the photo below. The relay is located under the rear storage compartment behind the passenger seat. This will accomplish exactly what you are trying to achieve.
Regards,
Dave
Been pouring over this site and glad I read this thread lol. This pic was very helpful! 👍
