Rubber in fourth!!!
Old Oct 21, 2002 | 12:43 PM
randy72's Avatar
randy72
Default Rubber in fourth!!!
I had to work yesterday (visit a supplier who's behind), so I chose to take the Vette to cheer myself up. During a spirited 2-3 shift, I got a fair amount of rubber, so I decided to try for the same on the 3-4 shift....It got rubber in 4th as well....Temp's were low fifty's, so the engine was making good power and the tires were cold. No wonder my 60 ft times suck.
Old Oct 21, 2002 | 01:10 PM
flood's Avatar
flood
Default Re: Rubber in fourth!!! (randy72)
I can get rubber in second, but thats it. Not bad for an L48 (bone stock).
I will someday be able to light up the tires in 4th, at least I hope to. That must be a ton of fun and really cool to see from behind the car ! :cheers:
Old Oct 21, 2002 | 07:53 PM
Ryan77's Avatar
Ryan77
Default Re: Rubber in fourth!!! (flood)
I too got 4th gear rubber back in June, that's only time I've ever tried.
Old Oct 21, 2002 | 08:24 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
Default Re: Rubber in fourth!!! (Ryan77)
:cheers: if i could do that, i would get rubber in neutral :crazy:
Old Oct 22, 2002 | 06:18 AM
Titanium Rat's Avatar
Titanium Rat
Default Re: Rubber in fourth!!! (Corzvette69)
only if you shift with your left hand :jester
Old Oct 22, 2002 | 09:52 AM
Alwyn678's Avatar
Alwyn678
not suprising.....mine will do it on the 2 to 3 shift with my auto
Old Oct 22, 2002 | 10:29 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
What's your tire size and engine HP???
:cheers:
Olivier
Old Oct 22, 2002 | 12:05 PM
randy72's Avatar
randy72
Default Re: Rubber in fourth!!! (GrandSportC3)
235/60/15 (also have f70x15's, but they're not on the car at the moment). Don't know engine HP, but I dyno'd 29x at 4800 at the wheels and 340 lbFt. @ the wheels. 300 tq. from 2500-5000! :chevy Guess 350 hp, 400 tq @ crank (net).
Old Oct 22, 2002 | 01:25 PM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
How much rubber are you getting? A chirp? Smoking them?
On the few trips I've made down the 1/4 mile, I get a nice chirp shifting into 4th at about 100mph. Very :cool:
Old Oct 22, 2002 | 05:52 PM
GrandSportC3
235's are not too wide... Especially if your tire pressure is above 30 psi - it's very easy to spin the tires.. Go with 275/60's on the rear and you won't even spin them between 2nd and 3rd...
:cheers:
Olivier
Old Oct 22, 2002 | 07:59 PM
dman535's Avatar
dman535
This is what happens when you get rubber in high gears.
Old Oct 24, 2002 | 07:52 AM
randy72's Avatar
randy72
Default Re: Rubber in fourth!!! (dman535)
I did that last June shifting to 2nd....Second trip to the track after new engine and 3.70 gears, on the F70 x 15's. First pass of the day.
I get a nice chirp into fourth, no huge amount of smoke/spin. This was shifting at about 3500 (close to peak torque).
Old Oct 24, 2002 | 08:16 AM
SLICKMAN's Avatar
SLICKMAN
I get rubber in every gear except for fourth, I'm running 255/60 - 15's all around.. Stock L82 :D
Old Oct 24, 2002 | 08:31 AM
theandies's Avatar
theandies
Default Re: Rubber in fourth!!! (SLICKMAN)
Cool,
I Chirp 4th all the time. Its fun.
John
Old Oct 24, 2002 | 12:02 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Make it go away !!
I don't want to see picutes like that! I am worried enough that the car is 23 years old, I don't like to think about things going "snap" as it's going down the 1/4 mile.
Old Oct 24, 2002 | 12:39 PM
gkull's Avatar
gkull
You must have low gears :) I've never got a chirp on a 3-4, but if I was shifting at redline in 3rd i would be going @ 125 mph
Old Oct 24, 2002 | 02:36 PM
randy72's Avatar
randy72
Default Re: Rubber in fourth!!! (BSeery)
Mine was rather non-eventful when it broke....Until my wife found out how much I spent to fix it.
Old Oct 24, 2002 | 09:03 PM
73 LS-4's Avatar
73 LS-4
I can do it more easily If I'm shifting at full throttle in the midrange then I can when I run the tach all the way up ( I can still sometimes). I think a really sticky clutch helps out a lot in doing this.
:cheers:
Pat Kunz
Old Oct 24, 2002 | 09:28 PM
Road Racer's Avatar
Road Racer
Default Re: Rubber in fourth!!! (73 LS-4)
:cool:
To Rubber in fourth!!!
