Spark Plugs
Old Jul 6, 2018 | 08:52 PM
speedracer2's Avatar
speedracer2
Default Spark Plugs
FYI Today I replaced my Bosch Platinum Plugs with Auto Lite Platinum Plugs. I have Headers on my '82. The Auto lite Plugs are approximately 1/4th inch longer. This caused a lot of problems, requiring pulling the rubber cushion out of the spark plug socket. What a bitch!!!!
Old Jul 6, 2018 | 09:37 PM
dmaxx3500's Avatar
dmaxx3500
ac delco plugs in gm
autolite in ford
champion in cslr
ngk/bosch/etc in foreign
Old Jul 6, 2018 | 10:03 PM
kbacklund's Avatar
kbacklund
I just replaced mine and used ACs. Had to do the same.
Old Jul 7, 2018 | 12:13 AM
REELAV8R's Avatar
REELAV8R
autolite in ford
champion in cslr
Why?
Old Jul 7, 2018 | 09:18 AM
HeadsU.P.'s Avatar
HeadsU.P.
autolite in ford
champion in cslr
Maybe 30 yrs ago. Some aluminum head manufacturers insist on NGKs for their extended reach in the chamber and excellent heat range options. That's on a SBC, which I do not believe is foreign but I can double check.
Old Jul 8, 2018 | 05:36 AM
fishslayer143's Avatar
fishslayer143
autolite in ford
champion in cslr
totally disagree.. I run Autolites or NGK in everything.. never an issue in 40 years .. I would not put a Champion plug even in a Weed Whacker.........make that 50 years ...brain fart
Last edited by fishslayer143; Jul 8, 2018 at 12:50 PM. Reason: spilled my beer..senior moment
Old Jul 8, 2018 | 12:11 PM
REELAV8R's Avatar
REELAV8R
Agree. Champion plugs were always garbage when I tried to run them. NGK have never failed me. All plugs do the same job so unless you know of a reason to not to use a plug then they should all perform well enough regardless of brand. That being said I have had good success with NGK or Autolites as well.
Construction of the plug would be a greater factor or tip material, or overall length, color to the tip ( for jetting reading) these would be my criteria vs just brand name.
Old Jul 9, 2018 | 05:41 AM
mr siesta01's Avatar
mr siesta01
7th Gear
Default spark plugs
Harley's in Japan, It'll work just seems out of place,
Old Jul 9, 2018 | 04:53 PM
MelWff's Avatar
MelWff
Use Accel shorty plugs intended for header applications.
To Spark Plugs
