bleeding brakes
Old Jul 8, 2018 | 05:14 PM
ronarndt's Avatar
ronarndt
Default bleeding brakes
I have been driving my 68 convert for over a year with a pesky small air bubble hung up somewhere in the left front caliper. Repeated bleedings with vacuum bleeding and pressure bleeding did not get the small amount of air out- it was just enough to make the left front brake work at about 50% of the braking force of the opposite right brake, so the car pulled to the right. Today I pressure bled the left front again while my helper used my air chisel to vibrate the caliper while bleeding. I put a piece of hard plastic tubing over the end of the chisel so it would not damage the caliper. It made enough vibration that it dislodged the air from wherever it was hung up. I finally have the car stopping straight as an arrow and it only took a year and pulling out half of my hair.
Old Jul 8, 2018 | 06:02 PM
HeadsU.P.'s Avatar
HeadsU.P.
Congrats, but:
I sure would hate to see how you guys get a bubble out of a new paint job!
Old Jul 8, 2018 | 06:56 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
good job! if you have lip seals vacuum bleeding doesn't work it sucks air in from around the lip seals
Old Jul 8, 2018 | 08:14 PM
ZRXGreen's Avatar
ZRXGreen
Good job.
Just saw this video today: would this work on the C3s?
Old Jul 9, 2018 | 03:31 AM
ariba's Avatar
ariba
Originally Posted by ZRXGreen
Good job.
https://www.youtube.com/watch?v=L0oUejw5Edc
Why I never thought of that
Old Jul 9, 2018 | 11:18 AM
bobs77vet's Avatar
bobs77vet
if your calipers have lip seals the answer is at best..... not very well and at worst NO....if they have O ring seals it probably will work...... I could never succesfully bleed my brakes using vacuum even though on many other cars it was my go to method
those one person bleeders with check valves in them work very well and so does gravity. i use a motive pressure bleeder for the c3 brakes
Old Jul 9, 2018 | 04:23 PM
ronarndt's Avatar
ronarndt
I replaced the bleed screws with SpeedBleeders on all of the calipers. The calipers, installed by the PO have o-ring seals, but the left front side would not spit out some small air bubble that was probably lodged in a rough spot on the interior casting, despite bleeding by both pressure and vacuum methods several times. I could have smacked the caliper with a mallet, but the air chisel set on low pressure did the same thing and worked. I've bled hundreds of drum and disc brakes and this was the most stubborn I have found. One of my lab technicians came up with the idea. We get rid of trapped air bubbles on chromatography columns using a little battery powered vibrator and hold it against the column and tubing while flowing buffer thru the system. The air chisel was just the industrial version.
Old Jul 9, 2018 | 10:11 PM
bobs77vet's Avatar
bobs77vet
good job I will have to remember that one, any reason an impact wrench on a low setting hitting caliper mounting bolts wouldn't do the same thing?
Old Jul 9, 2018 | 10:56 PM
ronarndt's Avatar
ronarndt
bobs77vet said "impact wrench on a low setting hitting caliper mounting bolts "
That probably would work too. When we clear the air out of our tubing and columns in the lab, you can see the air through the clear plastic tubing and housing. The vibration appears to break the surface tension and makes the air bubbles break free and float in the liquid so they can be flushed out. I am assuming something similar happens inside the caliper and tubing with air in the brake fluid.
Old Jul 10, 2018 | 11:04 AM
bobs77vet's Avatar
bobs77vet
i may try that next time...one person pumping, and me at the other end with a wrench on bleeder valve in one hand and battery operated impact on the other hand.....you could even use an impact driver on a low setting with the square drive adapter. all you need for it is to bounce around and get carried off in the flow. I wonder if works the same with silicone fluid that sometimes you need to let sit over night so all the bubbles group together and become one
Old Jul 10, 2018 | 12:15 PM
ronarndt's Avatar
ronarndt
Hope it works for you. It's frustrating going thru the procedure that works in 99% of the time and for some reason does not work for you. Good luck.
Old Jul 10, 2018 | 04:16 PM
bobs77vet's Avatar
bobs77vet
i think thats the entrance point for c3 brakes..it a reset button for all of us.
Old Jul 10, 2018 | 06:32 PM
kansas123's Avatar
kansas123
Yes, I also am getting tired of being the 100th person that stuff doesn't work for....
To bleeding brakes
