Question about Eaton Cone type posi
I have acquired a super clean differential unit that was rebuilt about two years ago. The owner decided to upgrade. I opened it up and it has the auburn cone type posi. I don't know anything about them good or bad. I found a hot rod magazine article on how to add shims to tighten them up. Are they good for your typical vette driver or should I pull it and install the typical clutch unit. I'm probably going to sell it because I don't need more spares sitting around. It has 3.55 gears in it
I have acquired a super clean differential unit that was rebuilt about two years ago. The owner decided to upgrade. I opened it up and it has the eaton cone type posi. I don't know anything about them good or bad. I found a hot rod magazine article on how to add shims to tighten them up. Are they good for your typical vette driver or should I pull it and install the typical clutch unit. I'm probably going to sell it because I don't need more spares sitting around. It has 3.55 gears in it
Mike
This came out of a running vette and it has the 2 year old paperwork for all new bearings, US gears 3.55 and the auburn posi unit. This could be installed as is or if somebody wanted to they could pull the caps, then ring gear and put in a Eaton clutch type posi and put it right back together because the lash and pattern are all good. It's shipping that kills sending this stuff. It doesn't have the yokes.
Mike
The flange dimension would most likely be off if you were to set them up side by side and measure them. The flange dimension would then dictate the shimming needed to set the lash and the pattern will determine where the pinion is. I suppose it's possible they would be very close but I wouldn't bet on it. Then you have the case of who last built it and was it right then? Some of the diff's I get in that were rebuilt by some guys, in say TX, are all over the place and would have or have failed in use.
