74 Cooling Issues
Old Jul 14, 2018 | 10:01 AM
dalane's Avatar
dalane
Default 74 Cooling Issues
Guys new C3 Owner here and new to the forum. Not a complete newby to forums as a member of Stovebolt Chev trucks and Ford N tractors, but nevertheless I will probably unintentionally violate a few formal and informal rules here. First violation, not searching the forum for immense discussion of the same issue before as if you're the first person to have the issue. I did a search, and found the discussion on electric fans and a few tangents but not exactly my issue. Here's my deal. 74 original 350 has been bored/stroked to 383 with aluminum heads, headers and new intake by prior owner. Appears fan shroud has been cut in 1/2 during the motor rebuild, so the fan (w/clutch) is about 1/2" behind the shroud. None of the fan is within the shroud. I AM NOT A NUMBERS MATCHING GUY ! Live in S. Texas with too many days of 100 deg weather. Took my new 74 on a 50 mile stroll yesterday, she ran fine at 200 deg until I sat idling while fiddling with my GPS,then temps started climbing. Instantly cooled back down once underway and air moving through the radiator. Has factory air BTW. I would prefer not to add electric fans, but cannot have a vehicle that runs hot in my climate. How would you guys proceed?
Old Jul 15, 2018 | 08:28 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by dalane
…ran fine at 200 deg until I sat idling...Instantly cooled back down once underway and air moving through the radiator...
You're okay. What you describe is normal.
Old Jul 15, 2018 | 09:59 AM
HeadsU.P.'s Avatar
HeadsU.P.
Unofficial Quotes:
A few degrees in timing will change a few degrees in temps.
Overheating at idle is a "air" circulation issue.
Overheating at speed is a "water" circulation issue.
With the fan outside of the shroud you are only getting 50-75% efficiency.
Old Jul 15, 2018 | 10:52 AM
OldCarBum's Avatar
OldCarBum
Start with a good aluminum radiator and new shroud.
Install a good high performance, high volume water pump like the edelbrock or others.
Look at anything that you can do to pull more air through the radiator at slow speeds or stopped like removing the front license plate and bracket and installing a center grille, replacing the front air dam.
Old Jul 15, 2018 | 11:55 AM
fishslayer143's Avatar
fishslayer143
check the fan CLUTCH.. its probably not holding.anymore... . get a good Hayden Severe Duty Thermal Clutch and it will make a huge difference... AND only cost you about $40
Old Jul 15, 2018 | 03:25 PM
dalane's Avatar
dalane
Thanks Fellas. Great input. Is there a simple way to troubleshoot a fan clutch?
To 74 Cooling Issues
