Tool to thin valve guide boss?
Old Jul 25, 2018 | 03:41 PM
v2racing's Avatar
v2racing
Adam, use paraffin wax on the carbide burrs for lube to prevent clogging. I even used bar soap in a pinch. Just spin the burr in the wax to fill the teeth before you start cutting. It will stop the burr clogging with aluminum and give you a much nicer finish. You'll be able to feel when it needs more wax.
On the valve shape, it really depends on the seat shape, the area of the port before the seat and the shape of the chamber from the seat out as to what valve shape works best. I worked on developing these shapes over decades of doing headwork. I had seat cutters I designed for my head machine and had Sunnen make them for me as well as cutters for the chamber. I used to have all my valves custom made to my specs so everything worked together in concert.
Don't worry about the guides. There is very little to be gained there unless the area just before and at the guide is too narrow. The guide takes up part of the cross sectional area there. You want to maintain the cross sectional area as you approach the bowl. I used to start widening the sides of the port just before and at the guide to maintain the cross section. This gave me much better results than removing the guide from the area.
Mike
Old Jul 25, 2018 | 03:58 PM
NewbVetteGuy's Avatar
NewbVetteGuy
Mike
Mike, good tip about the paraffin wax; is there anything I can do if I've already clogged up the carbide bit? (assuming not)
Most of what you're saying about 10 degree vs 12 degree valves, I realize I have no way to understand to make a determination for my situation, but Ferrea told me to ask Profiler very pointedly if they thought that the 195cc head would benefit from the 12 degree angle on the back of the valves or not; if they answer, I'll be good-to-go. If not then I'll avoid screwing anything up and I won't make any changes there.
I'm kind of shocked by what you said about the guides; I'm going to try to interpret what I THINK you said to see if I get it right: "The CSA at each point of the exhaust port is important and the head designer probably took into account the fact that a valve guide would be where it is and adjusted the width of the port around the valve guide to account for it. Removing the guide just screws up the port by giving it more area than the head's designer intended(adds more area / slows down the flow in the part of the port that now has increased CSA)."
Adam
Old Jul 25, 2018 | 04:58 PM
lionelhutz's Avatar
lionelhutz
I understand what you're thinking about extra valve support, but I believe the brass insert is soft enough that it won't be doing any useful supporting when sticking into the port like that.
The recommendations for cutting the guide down in the port will be for cutting the boss around the insert and also making the insert flush to the end of it.
I recently saw a cast head that had guide inserts put in it and there was a valve where a gap was left between the insert and the head. It was shoddy workmanship trying to fix a head with a lot of guide wear. The valve rather quickly pushed the insert out into that gap leaving the insert oval. Point is that the brass insert wasn't strong enough to hold shape without the head material supporting it.
Old Jul 25, 2018 | 07:48 PM
v2racing's Avatar
v2racing
Adam
Just start using the wax and the burr should clear itself.
I wouldn't say removing the guide would cause problems, but I doubt there will be much gain. You could use your burr to taper the end of the guide to make it a little more streamlined.
Mike
Old Jul 25, 2018 | 07:53 PM
v2racing's Avatar
v2racing
A bronze guide is a lot stiffer than you think, bronze is a fairly tuff material. Harleys, especially the old ones, have about a third of the guide hanging in the port. If you shorten them up, the guides life gets very short. I've seen valves bent pretty good and a bronze guide still be OK. The cast iron ones break if you hit anything.
Mike
Old Jul 25, 2018 | 08:33 PM
derekderek's Avatar
derekderek
As long as you are in there, do you have a 15° back cut on the intake valves...yet?
Old Jul 25, 2018 | 08:34 PM
derekderek's Avatar
derekderek
A harley is 2/5ths of a 5 cyl airplane radial from the 20's.
Old Jul 25, 2018 | 10:05 PM
cv67's Avatar
cv67
St. Jude Donor '05
v2 is giving good advice..ignore that vid of the guy cutting that guide down..
Ill look through my carbides, if I have what you need Ill mail it to you.
Tap Magic...try it sometime. It does help cut & keep your tool clear.
Old Jul 27, 2018 | 08:53 AM
NewbVetteGuy
No and I'm not convinced that I want the low lift flow that I'd gain from it with such a torque focused build. I think I'm in the "low lift flow, bad; high llift flow, good" camp right now.
Adam
Old Jul 27, 2018 | 08:59 AM
NewbVetteGuy
I came across a formula for estimating the min require valve guide length on SpeedTalk:
Valve Length * 1.15 * Valve stem diameter = min required
4.190 stock SBC * 1.15 * (11/32)=
4.190 * 1.15 * .34375 = 1.66"
It makes sense that the LONGER the valve, the more valve guide length you'd want, but I would've thought that the bigger the valve stem diameter, the more stable the valve would be and that you'd need LESS guide length as the valve stem diameter gets bigger.
The formula ignores valve lift completely which I'm pretty sure is supposed to be a major factor...
Adam
Old Jul 27, 2018 | 01:25 PM
NewbVetteGuy
Well, I found out that the Beam cutter won't work. It only cuts up to 0.500" wide; my valve stems are 0.530" wide. The beam cutter also makes a very sharp edge, which is a bad thing on the inside of the valve guide especially on the port side, apparently. Beam's next size up cutter is 1" which is just WAY too big.
A proper valve guide cutter like the CompCams 4726 is designed to cut the TOP of the guide to accommodate smaller ID valve seals (for things like triple springs); that tool is $80+ with the required arbor, it properly chamfers the inside of the valve guide but it won't SHORTEN the valve guide if I were to just use the tool on the bottom side of the guide. I guess I could go super BUBBA and use a big *** drill bit to cut the guide down but I don't trust that remotely.
I think this is just too much of a PITA and too expensive for what is probably a 1-2 CFM gain and I'm just going to use my carbide to roughly "tear drop" the guide... Not whatt I wanted, but way more doable/ way less of a pain and way less $$$.
Adam
Old Jul 27, 2018 | 02:12 PM
v2racing's Avatar
v2racing
Adam
Adam, you're worrying too much about this. Just do as you said and use your burr to radius off the end of the guide. It will be fine that way.
Mike
Old Jul 27, 2018 | 02:21 PM
  #33
derekderek's Avatar
derekderek
Your guides are cut down to fit a 530 guide on top. Big block guides are .617 or .620. I think sbc guides same or close.
Old Jul 27, 2018 | 02:58 PM
  #34
NewbVetteGuy
Mike
I'm a Myers-Briggs ENTP, overthinking things 2x too much just meets my minimum bar for taking action.
One of my favorite parts of having a hobby is that I'm allowed to over think things there way too much; my boss would never stand for it, I have to be productive / underthink things and just deal with the consequences at work.
-I had to go to professional brewing school in the UK and take a professional brewing industry certification exam @ Guinness in Dublin with their professional brewers to feel like I knew enough to make my own home brew beer in my garage... The Guinness guys were taking the exam to get a promotion, I was doing it for fun; they said "And what department do you work in, Yankee? We've never seen you before."
It wouldn't be as fun if I couldn't over think it; it would be work, then.
Adam
Old Jul 27, 2018 | 03:13 PM
  #35
ddawson's Avatar
ddawson
LOL my son has ENTP as his email address.
Old Jul 27, 2018 | 08:38 PM
  #36
derekderek's Avatar
derekderek
And then you drink that good home brew, which can run a bit high in alcohol and overthink some more.
Old Jul 27, 2018 | 09:09 PM
  #37
MCMLXIX's Avatar
MCMLXIX
Lye eats up aluminum and will clean up clogged cutting tools.
Oven cleaner or drain cleaner will work.
Takes paint and gunk of steel and cast iron to.
Protect your skin and eyes.
To Tool to thin valve guide boss?
Old Jul 28, 2018 | 08:35 AM
  #38
L88Plus's Avatar
L88Plus
How much difference do you think it'll make in airflow?
Is that worth the trouble and worry?
Old Jul 28, 2018 | 09:24 AM
  #39
derekderek's Avatar
derekderek
with some homework it looks like these guides are .500 OD. valves around .343 so there is .160 or so of guide there. .080 guide thickness. mebbe 82 or 83. and there is no boss blocking airflow like those procomp heads. I don't think it is worth it to mess with the guides if you start, you might as well trim some of the guide right off, leaving some but not as much protruding. a larger than .5 drill bit done freehand will also do the trick. but a flat cutter would be better.
Old Jul 28, 2018 | 11:42 AM
  #40
NewbVetteGuy
Guessing 1.5-2 CFM for shortening the guide and thinning it out. Significantly more than that from blending the bowls (they were bad with very sharp lips). A necked down valve with nothing else changed = 4 cfm switching from a standard Manley valve to a Ferrea Proflo according to Big Joe Sherman +6 cfm (only +2 extra over a necked down Manley valve). Going with a steeper valve head will trade a few cfm at low lift for a few cfm at high lift.
Maybe +10 or +12 CFM / 20-24 HP. Any of the gains that improve airflow without changing the valve curtain area or min CSA, improve velociity. An average cfm gain of 10 cfm with these heads is a 3.6% increase in average port speeds (port speed and torque correlate very closely).
Lets say all the cleanup with hand tools is 7 CFM, that’s 14 HP for your time/effort.
Maybe with a combo on the edge of detonation, like mine, polishing chambers or exhaust helps you run 1 or 2 degrees more timing - another couple HP.
They're tiny gains percentage wise but they can add up and they’re the fun gains, imho because you get them with your own hands.
Adam
