Transmission Gearing
Old Jul 24, 2018 | 09:33 PM
LoganA's Avatar
LoganA
1st Gear
Default Transmission Gearing
Hello everyone. I recently bought a 1970 Corvette with a 454 and 4 speed transmission. The guy I bought it from had done a lot to hot rod the engine and replaced the rear end with a ratio somewhere in the 4's so the thing really jumps off the line. However, I don't know if anything was ever done to the transmission and whats weird is that when I'm spinning about 2,000-2,500 RPMs in 1st and the go to 2nd gear, it suddenly ramps up to about 3,000-3,500 RPMs. Does anyone know what might be going on or have the same issue? I have a pretty basic understanding of cars but I just don't feel like this is normal.
Old Jul 25, 2018 | 01:17 AM
2mnyvets's Avatar
2mnyvets
You need to provide the gear, the vehicle speed and the Rpm. We will need one data point for each gear. Also, does the engine stay at 3500 RPM or does it drop to a lower RPM
Old Jul 25, 2018 | 05:40 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
check the shift rods. he could have the 1rst and 2nd shift arm upside down. He may have set it up for drag racing or something
Old Jul 25, 2018 | 08:56 AM
Bikespace's Avatar
Bikespace
1 and 2 reversed is all I can think of. Are you in contact with the PO? Did you test drive the car before purchasing it? Is there a custom **** or plate indicating a non-standard shift pattern? Perhaps post a photo of your shift levers underneath the car.
To Transmission Gearing
