antenna
Old Jul 29, 2018 | 11:59 AM
harmoe's Avatar
harmoe
Default antenna
how do you remove and replace the antenna on a 68 vette
Old Jul 29, 2018 | 03:25 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Uncsrew the antenna mast
Unscrew the round nut holding the base up and it will drop out the bottom. If it doesn't, leave it
Climb underneath and you'll see the big sheetmetal grounding support plate.
Unscrew the ground strap so you can clean it
Pull the antenna down through the hole and the plate should come down too.
The antenna cable should unbolt or uncrewed from the base. clean everything so you get a good ground.
Old Jul 29, 2018 | 03:35 PM
harmoe's Avatar
harmoe
thanks will give it a try
Old Jul 29, 2018 | 03:45 PM
Rescue Rogers
Heres a pic of the parts
To antenna
