70 Block Casting Date
Old Jul 30, 2018 | 07:11 PM
coznocoz's Avatar
coznocoz
Default 70 Block Casting Date
Have a 1970 350 engine with correct Casting Number but a Casting Date of M108. Any help would be appreciated
Old Jul 30, 2018 | 07:54 PM
Hammerhead Fred's Avatar
Hammerhead Fred
There is no "M" casting month/date.
Let's start with the block casting number off the rear driverside
and what are the engine code assembly numbers stamped into the passenger front pad?
Perhaps you have a production change block (pic would help).
Try reading this thread - has your same number (perhaps you purchased that car)
https://www.corvetteforum.com/forums...ine-block.html
Try this as well: https://www.corvetteforum.com/g/picture/1337041
Old Jul 31, 2018 | 06:37 PM
coznocoz's Avatar
coznocoz
Found out it was called a "special" block that had new production changes to the block. As I
understand it, these blocks all started with an M but the next number had to be a 1 or a 3, the
next one or two number are suppose to be the production sequence of changes. Have no support
data only a friend at Chevrolet that gave me the information.
Old Jul 31, 2018 | 07:41 PM
Hammerhead Fred
Should you click on the links provided in my initial response you'd discover the exact same information.
To 70 Block Casting Date
