Flow master super 44 resonance problem.
Old Aug 1, 2018 | 01:04 PM
Mitty's Avatar
Mitty
Default Flow master super 44 resonance problem.
Hi, I have a pair of flowmaster super 44’s on my 74, fed straight from ceramic coated short headers. The drone in the car at 1300-1800rpm is unbearable, it’s fine after, on load or not and at idle. Would sound proofing cure this? Or am I better off replacing the 44’s? It’s one piece welded so they’d need cutting off. Or could I add a centre resonator?
Thanks, Tim.
Old Aug 1, 2018 | 01:12 PM
Greg's Avatar
Greg
Just another Corvette guy
That won't stop the drone. I've had it too. It is unbearable on the freeway. Try switching to 40's. I just installed a pair on my '73 and they give good tone without the dreaded drone.
Old Aug 1, 2018 | 01:19 PM
Mitty's Avatar
Mitty
Cheers, so a muffler change then. Are the 40’s a direct fit, ie the same size?
Old Aug 1, 2018 | 02:24 PM
jim2527's Avatar
jim2527
40's on my C4 were horrid. I swapped them out for Walker Dynomax and was much happier.
Old Aug 1, 2018 | 02:43 PM
Mitty's Avatar
Mitty
Is that the super turbos?
Old Aug 1, 2018 | 03:06 PM
MelWff's Avatar
MelWff
On a 71 GTO with a drone from Pypes mufflers I went to the Dynomax VT, they use a valve that opens with back pressure.
Old Aug 1, 2018 | 03:26 PM
JoeMinnesota's Avatar
JoeMinnesota
I have 40's on my '70 with a hopped up 355, 2-1/2" all the way back and a smaller 1-1/2" H-Pipe behind the trans. One spot of resonance from 1600-1800 rpm otherwise beautiful, you can converse on the highway, awesome sound and it does not drone.
Before you cut those mufflers off, try having an H-pipe installed. You might be surprised.
Old Aug 1, 2018 | 03:29 PM
cv67's Avatar
cv67
St. Jude Donor '05
Get the biggest case turbo muffler you can under there, youll be much happier. Resonator wont get rid of the drone most aftermarkets are known for.
Doubt youll see any power loss at all.
Old Aug 1, 2018 | 06:45 PM
naramlee's Avatar
naramlee
get Pype Violators or Flowmaster 40 original NON- delta
either are my personal fave, Flowmasters have the famous purr and the Pype Violators have a deep raspy snarl
Pypes are a turbo style, far better flow than Flowmaster, but it's all about sound to me.
Pypes on my 408w, sounded great at idle, not too loud, but when you got on it on the freeway, it was insanely loud, but just cruising was barely even there, it was such a sleeper.... ruined a lot of c5 and c6's day with that car
Old Aug 1, 2018 | 07:27 PM
Crimson Thunder's Avatar
Crimson Thunder
I had Flowmaster 50's on my Vette before I put the side pipes on. Great deep tone with no drone.
Old Aug 1, 2018 | 07:45 PM
Mitty's Avatar
Mitty
Lots of ideas!
Does an H section make a difference? Mine are separate at the moment.
My main problem is I’m in the uk, so availability of some systems is awkward.
I can get the walker dynomax super turbo’s as mentioned above, would they be a good choice?
Old Aug 1, 2018 | 07:51 PM
Bloodzone's Avatar
Bloodzone
MagnaFlows
Old Aug 1, 2018 | 08:54 PM
ddawson's Avatar
ddawson
Magnaflows, and yes an H-Pipe may help or at least change it.
Old Aug 1, 2018 | 09:39 PM
OMF's Avatar
OMF
Going to the 40's won't help....they drone too.
As Crimson Thunder pointed out, the 50's do not drone, but they still have the nice sound of Flowmasters, I have them on my car too.
An H-pipe will tone down the sound some.
Old Aug 1, 2018 | 10:26 PM
Mitty's Avatar
Mitty
Great. A trip to my local friendly exhaust shops called for I think.
Old Aug 2, 2018 | 01:48 PM
c3_dk's Avatar
c3_dk
I have 40's they drone(1600-1800rpm), and they are on the way out now……..
Old Aug 2, 2018 | 02:23 PM
OldCarBum's Avatar
OldCarBum
Tests show that an H or X pipe in the system will increase performance and most people state it lessens or deletes the drone.
There have been several threads on this and U-Tube videos.
To Flow master super 44 resonance problem.
Old Aug 2, 2018 | 02:39 PM
Mitty's Avatar
Mitty
So an h pipe might be first port of call, either way it’s a bonus to have.
Old Aug 2, 2018 | 03:04 PM
C3 4ME's Avatar
C3 4ME
I too have Flowmaster 50's on mine, and no drone at all, but that well known Flowmaster sound, just a little quieter than other series.
Old Aug 2, 2018 | 05:59 PM
jim2527's Avatar
jim2527
Yes, they're good choice especially if you can get them local. Not sexy like Flowmasters but they'll get it done.
I had a removebable 'X' pipe on my '06 GTO, it'd take me all of 5 minutes to swap back and forth between it and straight pipes. The 'X' or 'H' will mellow it out but wont eliminate the drone.
