What size dome piston
Old Aug 1, 2018 | 03:47 PM
RIO68's Avatar
RIO68
Default What size dome piston
Mid 70's 350 bored 040 over using 882 heads, how much should the dome size be to get a 10 to 1 comp ratio or close to it. The block has not been decked. Heads checked out good shop checked them and ground the valves. Thks for any advice....
Old Aug 1, 2018 | 04:07 PM
GOSFAST's Avatar
GOSFAST
Will take a basic 12:1 piston (L2252AF or equivalent) with a 75/76 cc head to get in the area of 10:1 This piston uses a nominal 11 cc dome, one "positive", it does have a lighter weight ring pack!
Thanks, Gary in N.Y.
P.S. The one problem with building it this way is you won't be able to ever change over to any 64 cc heads later without running race fuel!!
Old Aug 1, 2018 | 04:08 PM
derekderek's Avatar
derekderek
Google compression ratio calculator. Standard head gasket dia is 4.125. Thickness .040. Not decked, pistons in hole .016 to .020, so use .018.
Old Aug 1, 2018 | 06:43 PM
derekderek's Avatar
derekderek
Just buy proper heads. Unless the 883 have yo be there for numbers. But the OP needs to calculate domes and chambers himself. Sort of homework assignment. Need to know how you got to a certain CR and had some input in the process...
Old Aug 2, 2018 | 12:53 PM
stingr69's Avatar
stingr69
Derek is not wrong, and Gary knows his stuff for sure.
My 2 cents - I would never re-install those 882's on anything unless it was a station wagon. Big chambers with big domes is not the answer.
Get SOMETHING better for heads and let the rest match your target. Those 882 heads are the worst parts you have under the hood. Smaller 64cc chambers will get you to 10:1 with ease and run hard.
Old Aug 2, 2018 | 11:01 PM
ronarndt's Avatar
ronarndt
Summit Racing has an on-line compression calculator.
To What size dome piston
