80 Brake hissing
Old Aug 4, 2018 | 11:04 AM
Warrenbic's Avatar
Warrenbic
Cruising
Default 80 Brake hissing
I recently took ownership of my father-in-laws 80 and while it drives there is an audible hissing sound when you depress the brake pedal. Is this normal or do I have a vacuum leak?
Old Aug 4, 2018 | 12:28 PM
3X2's Avatar
3X2
split diaphragm in the brake booster.
Old Aug 4, 2018 | 03:46 PM
Warrenbic's Avatar
Warrenbic
Cruising
Could it lead to total brake failure or is it just worse performance and annoying sound?
Old Aug 4, 2018 | 05:12 PM
sambrand's Avatar
sambrand
its serious, I would advise fixing asap, it can lead to total system fail if the problem is ignored, you would still have some brakes but u would have to repeatedly pump them to get any brake action, this assumes that its the diagphram only and the fluid lines are good.
Old Aug 4, 2018 | 05:31 PM
HeadsU.P.'s Avatar
HeadsU.P.
The loss of power assist, just means you have to push harder on the pedal. You still have firm brakes. Non-PB was the way it was for yrs until the *****-foot booster was invented.
Old Aug 4, 2018 | 05:43 PM
sambrand's Avatar
sambrand
agree, however if the diaghphram is failing because its being exposed to brake fluid from a leak.... ive seen this happen when wrong brake fluid type is used. I was unclear in explaining that part, my fail.
Old Aug 4, 2018 | 09:46 PM
Warrenbic's Avatar
Warrenbic
Cruising
This hiss is definitely inside the cabin, is that normal for a split diaphragm?
Old Aug 5, 2018 | 07:02 AM
3X2's Avatar
3X2
Is it a continual hiss as long as you are pushing on the brake pedal or is it one whoosh sound of air? Continual hiss would be a split diaphragm and you would have very little to no power assist. A single whoosh is atmospheric air entering the booster through the filter where the pedal rod enters the booster. Even with a booster not supplying assist, you still have the hydraulic sectioning functioning although with a lot more pedal effort. Even more than a manual brake car. You can remove the master cylinder from the booster and look/feel/wipe inside the booster for brake fluid and if fluid is present, replace/rebuild the master cylinder.
Old Aug 5, 2018 | 11:10 AM
Warrenbic's Avatar
Warrenbic
Cruising
Thanks! Yes it’s a continuous hiss. I was already looking at a hydro boost and a new master clutch so I guess I know what my next purchases will be...
anyone ever very bought one from this guy?
https://m.ebay.com/itm/NEW-68-82-C3-...-/301796584167
Old Aug 5, 2018 | 12:12 PM
3X2's Avatar
3X2
Why not either rebuild the current booster or buy a NEW one?
Old Aug 5, 2018 | 12:46 PM
sambrand's Avatar
sambrand
https://www.ecklerscorvette.com/1980...%2Fbrakes.html
that's the whole thing at ecklers, you should deal with one of the corvette suppliers , Wilcox is excellent, ecklers, zips, paragon corvette, Chicago corvette, corvette central, take your pick.. these guys specialize in corvette parts, Wilcox stands out brcuase they generally try to help you diagnose issue and or give advice on repairs, but they are all good, and dealing with one of the ones I listed you wont have to wonder if the merchant is reputable.
edited because link was broken
Warrenbic's Avatar
Warrenbic
Cruising
Simply for the added braking power, I was already planning to swap out the vacuum booster with a hydrobooster. fron what I have read they make a significant difference in the brakes on these.
Old Aug 5, 2018 | 06:15 PM
Warrenbic's Avatar
Warrenbic
Cruising
This would look pretty sweet though...
https://www.jegs.com/i/Tuff-Stuff/90...hoCwSQQAvD_BwE
To 80 Brake hissing
