ammeter
Old Aug 4, 2018 | 01:58 PM
calvette 11's Avatar
calvette 11
Default ammeter
I have a 76 corvette with electric fans duals. I keep blowing ammeters gauges. Can the use of 100 or 80amp alternators cause this ?
Has any one had this same problem? I have blow four
Old Aug 4, 2018 | 02:15 PM
ronarndt's Avatar
ronarndt
calvette- It is more likely you have a short in the circuit going to your gauge. I have fans and alternator like yours. I had the ammeter in my 68 short out due to the metal case of the gauge not being properly insulated from the frame of the center console. Also- not sure if the wiring on your 76 is the same, but on the 1968 the wiring included short sections of "fusible links" which were designed to melt, like a slow-acting fuse, to protect the circuit from really overheating and causing a fire if there was a dead short.
Old Aug 4, 2018 | 02:45 PM
carriljc's Avatar
carriljc
No. The alternator only supplies the demanded amps.
Your problem is not the alternator capacity.
To ammeter
