1969 Coupe - Vacuum system issue
Old Aug 5, 2018 | 03:28 PM
The_Mace's Avatar
The_Mace
1st Gear
Default 1969 Coupe - Vacuum system issue
Hello... I have a 1969 C3 Coupe, 350, auto. A new issue revealed itself today... Neither the wiper door nor the headlights will operate (they won't move). I have checked all of the vacuum lines and everything seems to be OK. Each system worked when I last tried to use them, about 3 weeks ago. I have tried researching this topic on this and other forums, but most information I find deals with EITHER the wiper door or the headlights, not both. I also ran the car today and noticed it has developed a bit of a backfire, which is often attributed to an actuator seal leak...but I don't know why the entire vacuum system would go down.
EDIT: Problem solved. One of the vacuum lines wasn't as "OK" as I first thought. Backfiring still exists, which may be a separate problem.
