AC-Delco plug ??
Old Oct 23, 2002 | 12:20 AM
7tea1's Avatar
7tea1
Default AC-Delco plug ??
What is the difference between the R44TS and the R44TSX?????
The genius behind the parts counter had no clue :lol:
Old Oct 23, 2002 | 12:24 AM
SharkAttack's Avatar
SharkAttack
Default Re: AC-Delco plug ?? (7tea1)
If I remember correctly...
44 = heat range
TS = tapered shell
X = extended tip
Old Oct 23, 2002 | 12:34 AM
shoptek's Avatar
shoptek
Default Re: AC-Delco plug ?? (SharkAttack)
Any advantage/disadvantage to the extended tip??
I was getting new plugs a year ago and was asked do I want the ts or the tsx. Neither me or the guy at AutoZone had a clue about the X designation.
[Modified by shoptek, 11:34 PM 10/22/2002]
Old Oct 23, 2002 | 06:24 AM
Larry B.'s Avatar
Larry B.
Default Re: AC-Delco plug ?? (shoptek)
Go to A/C delco web site. There is a section on plugs. Small block Chevy's love Autolite plugs though. I belive the number is 25 or 26 but they change numbering codes a lot so use the cross reference chart.
[Modified by silvervetteman, 5:42 AM 10/23/2002]
Old Oct 23, 2002 | 07:44 AM
V8yunkie's Avatar
V8yunkie
Default Re: AC-Delco plug ?? (silvervetteman)
The X-plugs have a gap of 0,060 inches rather than the 0,046 inches of the normal type. They are intended to be used with the early HEI-distributors.
Reason is, that the HEI-distr. puts out much more voltage then the old distributors. Therefore you can use a larger gap thus obtaining a bigger spark. After 3 years, GM discovered that if they would use the smaller gap again, the spark plugs can be driven much longer. Simply because when a plug wears, the gap becomes bigger over time due to spark-errosion. The old distibutor could not handle the larger gap - therefore plugs had to be changed earlier (or had to be regapped). The HEI could easily live pretty long with a gap that becomes bigger over time (starting from 0,045).
So only use a X-plug if you have a coil that puts out the same voltage as a HEI-coil. Otherwise, the larger gap will ruin a stock coil. Or if the coil is already in worn condition, you will have no proper plug at all.
Old Oct 23, 2002 | 07:29 PM
JJ Deuce's Avatar
JJ Deuce
Default Re: AC-Delco plug ?? (V8yunkie)
forget about it - run the AC Delco Rapidfires. I think the small blocks take a #7. :cheers:
To AC-Delco plug ??
