Installing the Steeroids Steering Unit
Old Oct 23, 2002 | 07:40 AM
Arkansas Flash's Avatar
Arkansas Flash
Default Installing the Steeroids Steering Unit
I purchased a Steeroids rack and pinion steering unit through the group purchase that the captain set up. I remember reading about one of the mounting plates having a hole drilled slightly off or something. I am going to have mine chrome plated and I'd like to get that part drilled correctly before I send it to the platers. Can anyone tell me exactly what I need to do to correct that problem.
Thanks in advance.
Old Oct 23, 2002 | 11:58 AM
carlislewax's Avatar
carlislewax
Default Re: Installing the Steeroids Steering Unit (Arkansas Flash)
There was a big article in Vette mag about it with photos and installation. I'll look tonight to see if I can find the article and review. I'll let you know tomorrow if no one gets back to you before then.
Bob
Old Oct 23, 2002 | 01:38 PM
groovyjay's Avatar
groovyjay
All the mounting plates were direct bolt-ons for me :confused: . Chromed? Sounds great! Keep us posted. :cheers:
Old Oct 23, 2002 | 02:00 PM
Tomi72's Avatar
Tomi72
The drivers side bracket and the gusset are bolted together with two nuts and bolts. I had to enlarge the holes just a little bit to get the bolts through.
rgds Tomi
[Modified by Tomi72, 8:01 PM 10/23/2002]
Old Oct 23, 2002 | 02:48 PM
Monty's Avatar
Monty
That may have been from my posts, when I installed my Steeroids kit the first week of last January. On the right side mounting bracket, one of the holes in the bracket was about 1/2"off, and didn't align with the holes/bolts from the rack mount. I just redrilled the hole in the bracket in the correct spot. It was no big deal, but since I had one of the first kits I called them just to let them know. They said it could be due to the fact that they get their racks from a couple of different suppliers and it was just alittle different bolt pattern. I don't know about that, but in any case it was no big deal. It's still a very high quality kit and very easy to install.
Old Oct 23, 2002 | 09:18 PM
Arkansas Flash
Default Re: Installing the Steeroids Steering Unit (Monty)
Thanks everyone. I was just worried that I would get everything chromed and then find I had a problem that could only be modified by ruining the chrome on a piece. As soon as it arrives, I'm going to disassemble it and send it to the chrome shop.
To Installing the Steeroids Steering Unit
