Parking Brake Slider
Old Aug 9, 2018 | 04:15 PM
sjstub's Avatar
sjstub
Life Member
Default Parking Brake Slider
Do I have to remove the parking brake handle (4 bolts) in order to install a new slider on my '69?
Old Aug 9, 2018 | 04:24 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
No. Remove the ebrake console. Take off the old slider; put on the new. Put the ebrake console back on.
Old Aug 10, 2018 | 12:16 AM
ronarndt's Avatar
ronarndt
There is a nearly invisible joint/cut in the slider hole that allows you to carefully slip it on the handle. Remove the console as suggested by Easy Mike to make it easier to get everything lined up.
Old Aug 10, 2018 | 03:45 AM
sjstub's Avatar
sjstub
Life Member
Default Thanks
Thanks!
To Parking Brake Slider
