Pulsing through steering wheel, pulling away/reversing
Hi, I have a 74 with th400, and when reversing out of the garage, or very slow manoeuvres, putting the car in or out of the garage, often with foot riding the brake, I get a pulsing through the steering wheel, that can be felt on the brake pedal also.
I’ve just installed a new Borgeson steering box, and it did it before this, and after.
The pulsing is faster than the rotation speed of the driveshaft or half shafts, and I don’t notice it when driving normally, under braking etc.
I’m wandering if the trans is at fault, torque converter or something?
That’s a strange set of symptoms. It could be the trans mount is starting to rip. Try giving it a little gas while in reverse. If it gets worse, check the mount. Other than that I would check the brakes. A dragging caliper can make the steering pull.
