Which starter is the best
Old Aug 15, 2018 | 01:08 AM
OldCarBum's Avatar
OldCarBum
Default Which starter is the best
I'm building the big block in my 73 and looking into which starter is the best.
I've heard that mini starters are the way to go and I'm wondering who makes the best quality and what specs are needed for my big block 496 cu in?
Old Aug 15, 2018 | 01:32 AM
naramlee's Avatar
naramlee
yes, they are... heck I nearly broke a toe moving the factory starter from my L-48... the darn thing weighs almost 40lbs... forget that
we've been using ebay starters in our race cars for prolly the last 8 years, they are dam cheap and hold up even to our 16:1 alcohol engine... yeah they are no-name china crap... but they work
what really put the finishing touch was when one of our racing friend went and bought the top-of-the-line Meziere racing starter, almost 600.00... and it crapped out after like the 10th pass and Meziere wouldn't warrant it, they would rebuild it, but not replace it. Sure, it's been run, it's no longer new... but less than two weeks into racing and it craps out? common guys...
so yeah... we've had a few starters last only a few seasons from ebay, but we still have some that are going strong 5+ years later..
my .02 worth
Old Aug 15, 2018 | 02:03 AM
gkull's Avatar
gkull
Gear reduction starters from summit racing just get the highest hp level. I think that mine is 4.3 hp multiple position and dual flywheel tooth
Old Aug 15, 2018 | 08:20 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
I just went with a powermaster 9526 XS starter. It is a really nice part. I should know how it works in a month when I fire up the engine.
Old Aug 15, 2018 | 11:13 AM
OldCarBum's Avatar
OldCarBum
Thanks gkull, can you explain what dual flywheel tooth is and what advantage it gives me?
Old Aug 15, 2018 | 11:28 AM
TimAT's Avatar
TimAT
I'm using this one-- but I can't see spending $300 for a starter when I can get 5 of these. And so far, it's spinning a 10.5:1 compression 496 like it's a 5hp Briggs. Zero complaints.
https://www.dbelectrical.com/product...sdr0031-l.html
Old Aug 15, 2018 | 11:50 AM
gkull's Avatar
gkull
Chevy kinda used 168 tooth flywheels and flex plates on Big Blocks. Small blocks got 153 teeth.
I was wrong mine is only 3.4 HP. I'm not an e-bay person and I would rather spend money on something that can last a lifetime. I've used this one starter on 6 different motors in my vette.
https://www.summitracing.com/parts/pwm-9400/overview/
Old Aug 15, 2018 | 12:29 PM
naramlee's Avatar
naramlee
yeah thats kinda what our bud thought his Meziere starter was supposed to be, my cars all have XS powermasters, race cars are ebay specials
Old Aug 15, 2018 | 12:34 PM
v2racing's Avatar
v2racing
I've used Ebay cheap mini starters on multiple cars with zero problems. I had one on my 64 Impala SS for almost 10 years.
Mike
Old Aug 15, 2018 | 01:28 PM
jasper711's Avatar
jasper711
Rob McC mini-starters have worked well for me in three hobby cars. They are highly acclaimed in some of the more obscure specialty forums (i.e.: ford FE, Pontiac etc.) but also work well on my corvette.
http://www.robbmcperformance.com/pro...rter_home.html
Old Aug 15, 2018 | 01:47 PM
NewbVetteGuy's Avatar
NewbVetteGuy
I'm with you on this one. The starter has plastic internals and they don't last long but just buy two of them for $100 and leave the spare sitting on the shelf waiting to go. They're also super light because of all the aluminum and plastic. ;-)
Adam
Old Aug 15, 2018 | 02:31 PM
cv67's Avatar
cv67
St. Jude Donor '05
Bought a $60 mini starter from Pomona Swap meet around 2000?Been on 3 motors so far so good.
Hard to beat a GM type mini....I like the quietness of the factory high torques but they are just too big and heavy.
When it dies Ill spend 35-40 and have it rebuilt, same as the alternator. Those 2 peices are grossly overpriced new .
Old Aug 15, 2018 | 03:11 PM
naramlee's Avatar
naramlee
when it dies ill spend 35-40 and have it rebuilt, same as the alternator. Those 2 peices are grossly overpriced new .
amen brother!
Old Aug 15, 2018 | 03:49 PM
NewbVetteGuy
Wow, that DOES look like a super nice starter (and 8.5 lbs is nice, too).
If I destroy 2 $50 chinese el-cheapos and get sick of replacing them, I might spring for one of these.
Adam
Old Aug 15, 2018 | 04:11 PM
jasper711's Avatar
jasper711
Adam
I met Rob once and he had worked as a designer/engineer at some other aftermarket manufacturer(s) that were bought out. I believe he personally is involved in the manufacture of these ministarters.
Old Aug 15, 2018 | 04:16 PM
Sigforty's Avatar
Sigforty
Adam
He makes a good looking fuel pump as well. He is also does 1/2" fuel senders for corvette and other GM muscle era vehicles.
Old Aug 15, 2018 | 09:55 PM
ddawson's Avatar
ddawson
I've had the same starter for 3 years now and no issues.
Old Aug 16, 2018 | 12:32 AM
OldCarBum's Avatar
OldCarBum
That's kind of my thinking too.
I didn't know they built starters that could be used on 153 or 168 tooth flywheels.
To Which starter is the best
