Whining from dash speedo area
Old Aug 15, 2018 | 03:39 PM
Ryan Sidwell's Avatar
Ryan Sidwell
Default Whining from dash speedo area
Hi guys so I installed a new intellitronics dash and now when I turn the car off I get a high pitched whine from the dash area. Lasts a few seconds and stops. Any idea what it might be? Also it doesn’t seem to be consistent on the length of time that the whining lasts.
Thanks Ryan
Old Aug 15, 2018 | 04:07 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Have you contacted customer services at Intellitronics?
Old Aug 15, 2018 | 06:15 PM
kansas123's Avatar
kansas123
Is there still any vacuum hoses behind the dash? I had a noise like that which was caused by a small leak in a vacuum hose, explaining why it never lasted the same length of time and the leak was so small it reminded me of the sound a balloon makes when you grab either side of the end you blow up and pull them apart from each other (if that makes any sense). Just a thought.........
To Whining from dash speedo area
