Prom in ECM Backwards
Old Aug 15, 2018 | 09:30 PM
Wrecked82's Avatar
Wrecked82
Default Prom in ECM Backwards
Hypothetical (mostly). What happens if you put the prom into the ecm (82 ecm) backwards and apply power. After the "pop" what is damaged - the prom or the ecm or both.
Admit, I did this several years ago and went to the stock prom, not the backwards hypertech. Did that have any negative effect on the ecm? Had to replace the ecm last week and car is running as good as ever now. Wonder if I screwed the pooch on the backwards insertion of the prom. I know all about how to do it right. But I still did it backwards.
Old Aug 15, 2018 | 09:33 PM
av81's Avatar
av81
The ecm is fuse protected so I doubt you blew it , the prom thats another story
Old Aug 15, 2018 | 09:37 PM
Wrecked82's Avatar
Wrecked82
That is what I thought, but wanted to ask anyway. Going to throw away the fried chip. No reason to keep it.
Old Aug 15, 2018 | 10:42 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
OHhhhhhhh...That sux for sure! You should be OK with the ECM, but the PROM is toast for sure. It applys power where it shouldn't when in backwards. The best way to prevent that from happening in the future is to mark the PROM with a dab of white paint on pin #1 and on the socket or use a silver magic marker. Hope all goes well.
Old Aug 16, 2018 | 01:05 PM
The Money Pit's Avatar
The Money Pit
EPROM for sure. I'm a tech that sees that sort of thing all the time. Sometimes they get so hot the epoxy case burns a hole in itself.
New EPROM fixes the problem
Old Aug 18, 2018 | 08:38 PM
LT1M21Vette's Avatar
LT1M21Vette
The PROM and the socket are already market with a notch for the correct way to insert it.
Most PROM are toast if you plug them the other way around.
Old Aug 19, 2018 | 12:54 PM
Buccaneer's Avatar
Buccaneer
Yeah...I know that, but for others that may overlook that it helps to have a reminder (white paint or whatever) to match up the color ends together...Jus sayin'.
Old Aug 19, 2018 | 04:00 PM
LT1M21Vette
Give a Man a Fish, and You Feed Him for a Day. Teach a Man To Fish, and You Feed Him for a Lifetime.
Old Aug 20, 2018 | 03:02 PM
Wrecked82's Avatar
Wrecked82
I knew about the notch on the carrier and the mark on the chip. I simply was tired and did not pay attention enough. Simple as that.
Old Aug 21, 2018 | 12:31 PM
jeffwebley's Avatar
jeffwebley
I used to have an 82 Z-28 and those eproms were also very susceptible to static electricity discharge damage.
Old Aug 21, 2018 | 03:54 PM
Buccaneer's Avatar
Buccaneer
OK, that's just not true. The 82/84 EPROM or EEPROM Corvette or 82/83 Camaro, Firebird and Trans AM are not any more susceptible to static or ESD damage than any other EPROM/EEPROM made. If the discharge from your body or whatever else is high enough, it can zap a chip without you knowing it until you plug it in. It is ALWAYS good practice to ground yourself properly before handling those type of devices. Glad you got it fixed.
Old Aug 22, 2018 | 02:45 AM
jeffwebley's Avatar
jeffwebley
Still doesn't change what I said, the chips are susceptible to ESD damage. I never messed with anything other than the Z-28 chips, and have pulled a few out of brand new packaging, using a ground strap on my wrist, not touching anything but the body of the chip and they were DOA. Doesn't really matter, after I sold my Z, went and bought a 2001 Cadillac ESC, no chips to play with, just reprogramming the whole ecm. Now I just set the cruise, play with the radio, and keep it between the lines. Cheers
Old Aug 22, 2018 | 07:34 AM
L88Plus's Avatar
L88Plus
Nope.
Give a man a fish and you feed him for a day.
Teach a man to fish and he'll sit in a boat and drink beer all day.
Old Aug 22, 2018 | 10:44 AM
Buccaneer's Avatar
Buccaneer
WOW! I guess people just don't read what is posted and only what they want to read. Here's what I said in reply...
This is a TRUE statement in itself. I'm not or wasn't saying that you did not have a blown chip or that you did not received bad chips DOA that you mentioned in your last post, it happens and that's why we stopped burning PROM chips for the 84. One, they were and still are hard to find and even in quantity and two, they have a somewhat high failure rate. This DOES NOT mean that they are more easily damaged by static than others, it just happens just like any other chip made that is ESD sensitive. After working for Motorola in the semi-conductor sector for a number of years, I can tell you a lot about ESD and chips and how easily they can be ruined... jus sayin. I hope this clears up my first reply, if not, what can I say?
Old Aug 22, 2018 | 01:34 PM
jeffwebley's Avatar
jeffwebley
Dudeman turn off your flamethrower and read the first sentence you wrote. All I did was comment that in my experience, the chips that I have encountered, have been delicate. Fortunately, I have progressed beyond chips.
To the OP, I apologize if I have given you incorrect information.
Old Aug 24, 2018 | 12:17 PM
Tslayer66's Avatar
Tslayer66
just went through the hypertech chip install myself. Installed while ECU still mounted behind seat. After working with for awhile finally decided just to install without that green holder/ housing. Installed in seconds that way without bending of prongs and no engine light on. Can I leave it that way with no future problems? Or does that housing provide some value?
Old Aug 24, 2018 | 03:16 PM
lionelhutz's Avatar
lionelhutz
WOW! I guess people just don't read what is posted and only what they want to read....
I suggest you try re-reading yourself too then. jeffwebley never wrote that the EEPROMs used in his 82 Z-28 were more susceptible to damage than any other EEPROM.
To Prom in ECM Backwards
