TH400 Question
Old Aug 16, 2018 | 11:44 AM
DAD111's Avatar
DAD111
Default TH400 Question
New Vette owner – 1975 with I think TH400 Trans because the shifter has overdrive. Motor and trans missing of course . Wanting to keep it stock, so no 700/200 swap. Question when looking for a trans, what should I be looking for – Years, Length, Tail shaft, Yoke Ect
Note: The yoke and drive shaft still intact.
Thank, Mike
Old Aug 16, 2018 | 12:03 PM
Factoid's Avatar
Factoid
A TH400 is a three speed automatic transmission used behind most big block GM engines, but it is not an overdrive.
Old Aug 16, 2018 | 12:08 PM
DAD111's Avatar
DAD111
OK so im confused - Sorry for the stupid questions, never worked with an auto trans always a manual. So what should i be looking for?
Old Aug 16, 2018 | 01:18 PM
Mooser's Avatar
Mooser
I believe they used the TH400 in all vettes up to 76 and switched mid-year to the TH350
M
Old Aug 16, 2018 | 04:04 PM
DAD111's Avatar
DAD111
OK, Thanks. So let me ask this - I bought the car from a guy that is friends of friends buddy - Whoooo. I have the title! So he knows nothing about the car so i am trying to figure out what i have. Brand new console with shiftier and shift indicator plate and it has 1st,2nd,3rd and o for overdrive. So i assumed Chevy made a overdrive trans for that year. Now after doing a bunch of reading im guessing it had a 400r trans in it? I see that they make a overdrive kit for the Vette. So it could be possible. - Am i thinking right or wayyyyyyy off.
Thank, Mike
Old Aug 16, 2018 | 04:16 PM
Mooser's Avatar
Mooser
Chev didn't make an overdrive until around 81 or 82. Someone may have changed your car and installed a 200r or 700r but it left the factory with a TH400
M
82 all had overdrive, not sure if 81 had it as an option or not
M
Old Aug 16, 2018 | 04:25 PM
DAD111's Avatar
DAD111
Great thats an answer that i was looking for. So what signs can i look for - Cross member bracket change?
Old Aug 16, 2018 | 04:32 PM
Factoid's Avatar
Factoid
The TH400 was the only automatic available that year. Frankly, it is heavy and a bit of a torque hog (meaning less torque to the rear wheels). Since your car is not original and you have to find a new drive train anyway, why not go with an overdrive tranny? I have a 700R4 in my 1961 and I like it, but it does have a bit of a sharp shift between 1st and 2nd given the wide ratio between those gears. 2004R trannies are pretty stout and might be a better solution for you. What engine and how much HP/TQ are you thinking?
Old Aug 16, 2018 | 04:44 PM
DAD111's Avatar
DAD111
350 hp max . I have a 68 350 that I am rebuilding. Mild build
Old Aug 16, 2018 | 04:48 PM
Mooser's Avatar
Mooser
I would also suggest the 200R
You said you have the trans yoke still on the driveshaft, You could measure the diameter of the shaft just behind the yoke to see if you can tell what trans might have been in there (200r4 or 700r are the two most common swaps if it was an overdrive as your console shows)
M
Old Aug 16, 2018 | 05:01 PM
Jeffs82c3's Avatar
Jeffs82c3
The first 700r4 were installed in the 82 corvette...
Old Aug 16, 2018 | 05:15 PM
Mooser's Avatar
Mooser
Check to see if the bracket is still on the shifter cable hanging under the car
M
Old Aug 16, 2018 | 05:21 PM
DAD111's Avatar
DAD111
Will do. Thanks
Old Aug 16, 2018 | 07:52 PM
DAD111's Avatar
DAD111
1.5 inches OD the shaft that goes into the trans
Old Aug 16, 2018 | 07:59 PM
DAD111's Avatar
DAD111
No shifter bracket. New shift cable
Old Aug 16, 2018 | 08:42 PM
derekderek's Avatar
derekderek
And driveshaft length. 400 is same as 4 speed. 200 and 700 are shorter. Not sure but I think 3.5 inches shorter. Or I might be thinking T5 3.5 inch difference.
Old Aug 16, 2018 | 08:45 PM
riverracer au's Avatar
riverracer au
remove center console and see if an aftermarket "shiftworks" detent horseshoe and "decal" is fitted.
https://shiftworks.com/collections/c...=3303151239189
To TH400 Question
Old Aug 16, 2018 | 09:19 PM
Kevova's Avatar
Kevova
Turbo 400 700r4 and 200-4r all are about the same length. The 400 has a larger 32 spline output shaft. The thm 350, 700r4 and 200-4r and all 4 speeds except the super T10 second design uses a smaller 27? Spline output shaft. The transmission pan is the easiest way to identify what you have. It's possible someone swapped in a o/d trans and shifter assembly from a 81-82.
Old Aug 16, 2018 | 09:26 PM
DAD111's Avatar
DAD111
Drive shaft length. Center of yoke to center of yoke is 29.5 inches
Old Aug 16, 2018 | 10:14 PM
DAD111's Avatar
DAD111
That's center of U Joint. I'm thinking he was going with the 200R
