74 Power Window regulator rebuild kit
Old Aug 18, 2018 | 10:57 AM
dalane's Avatar
dalane
Default 74 Power Window regulator rebuild kit
What am I missing? Just purchased a rebuild kit from Ecklers and the big rivet that holds the spring is not included. Is it possible to replace the gear teeth without replacing that rivet? I have to buy the rivet separately (and don't even see it on ecklers site). Must be missing something?
Old Aug 18, 2018 | 03:39 PM
SwampeastMike's Avatar
SwampeastMike
If you have what I believe the new piece with the teeth is intended to be attached (riveted) to the original. I presume regular pop rivets will work fine. The gear on the motor is still long enough to engage and it saves buying an entire regulator.
Old Aug 18, 2018 | 10:12 PM
dalane's Avatar
dalane
Here is the link. Is that a clip? How does that sucker come off? Don't want to break anything.
Regulator Rivet
Old Aug 19, 2018 | 08:21 PM
dalane's Avatar
dalane
Well the answer is no, you cannot replace the gear teeth plate without removing that big center rivet that holds the spring. It is total BS that all vendors sell the rebuild kit without that rivet. You have to buy it separately. Going to give it a try, have a local vette shop that can help make sure I get it on right.
To 74 Power Window regulator rebuild kit
