Manual transmission reverse switch wire
Old Aug 19, 2018 | 10:22 PM
BKelly78's Avatar
BKelly78
Cruising
Default Manual transmission reverse switch wire
I am finally putting my 78 back together. I remember at one time the reverse light switch wiring was there and everything worked as it should. When the body was off the chassis, I looked for the neutral and reverse switch wiring and didn’t see any kind of wiring in the transmission tunnel. Where would I find the information that would tell me what color wires for the neutral and reverse back up light switch that I’m looking for or how many wires there should be and where they come from?
Old Aug 19, 2018 | 11:02 PM
ronarndt's Avatar
ronarndt
On my 68 the reverse switch had pink and green wires. The plug on the wiring harness was on the engine side of the firewall about 18 inches below the top of the intake manifold next to the firewall where it plugged into the matching plug and wires that went to the reverse switch on the transmission.
Old Aug 20, 2018 | 05:30 AM
BKelly78's Avatar
BKelly78
Cruising
I’ll take a look to see if I have something similar. My other problem is, while I had everything apart my 4 speed transmission was stolen so now I don’t know what the switch or plug looks like to match. I have since bought a 5 speed TREMEC. Thanks for the help.
Old Aug 21, 2018 | 01:03 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Pink and green wires, short them together to turn on your backup lights.
To Manual transmission reverse switch wire
