Carb backfiring at high speed
Old Oct 23, 2002 | 08:43 PM
SharkBit's Avatar
SharkBit
Default Carb backfiring at high speed
Guys, gotta problem with my holley 750 vacuum secondary.
when i accelerate, it backfires, not bad, just a lot, especially 4k and above
new power valve too, what could it be?
timing too advanced or retarded?
btw, i have new fuel pump on it
and thanks
Old Oct 23, 2002 | 08:58 PM
Johns 61's Avatar
Johns 61
Default Re: Carb backfiring at high speed (SharkBit)
You can only backfire if the ignition sparks while an intake valve is open, I had a sticky valve cause this.
Old Oct 23, 2002 | 09:00 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
if it backfires thru the carb the carb is too lean or a lobe off the cam :chevy
Old Oct 23, 2002 | 10:49 PM
SharkBit's Avatar
SharkBit
Default Re: Carb backfiring at high speed (clem zahrobsky)
could it be a rocker too loose?
it dont do it all the time, just in high revs during acceleration
[Modified by SharkBit, 2:50 AM 10/24/2002]
Old Oct 24, 2002 | 04:29 PM
SharkBit's Avatar
SharkBit
ttt
Old Oct 24, 2002 | 05:30 PM
wcj's Avatar
wcj
car could be running to lean, arc in distributor cap causing misfire, floating valve, vacuum advance diaphram in distributor or advance weight springs causing to much advance although the last one should also cause a ping. I think it's probably a lean carb. Check to see if fuel is running through the secondaries when you crack them open. you can do this at a slightly higher than normal idle. there is also an enrichment valve that sits in the fuel metering block on a holley carb check this also. wcj
Old Oct 24, 2002 | 05:47 PM
Wrencher's Avatar
Wrencher
I'd bet bad/broken intake valve spring or flat intake lobe on the cam. How's that for a long range snap diagnosis? Let us know what you find.
Hans
Old Oct 24, 2002 | 06:04 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
The most obivous thing is that the car exhibits symptoms of running lean, check your fuel filters and your fuel pump. If the filter is partially plugged or you have low flow from the pump it will misfire on acceleration and above 4000 rpm.
At least 3 or 4 times a year someone posts with these same identical symptoms and 90% of the time it is fuel flow related.
Good Luck!
To Carb backfiring at high speed
