Engine will not crank
Old Aug 24, 2018 | 01:51 PM
rodney25's Avatar
rodney25
Default Engine will not crank
Hi All,
I just finished tuning up the car and all is project, engine runs beautifully. 30min later I turn the key and the engine will not crank at all. I thought it was that feature that the clutch had to be depressed for the engine to crank. Is there a way to disable this so I rule it out as the cause of the engine not cranking?
Also what else could cause this issue?
