Cam motion feedback
Old Aug 24, 2018 | 05:00 PM
jwp2's Avatar
jwp2
Default Cam motion feedback
About ready to buy a cam package for an LS Swap in my 78 project. Thinking about cam motion or comp cams.
Doea anyone have any feedback good or bad about cam motion?
let me know! Thanks. JP
Old Aug 24, 2018 | 05:22 PM
76strokervette's Avatar
76strokervette
Although I personally have not used cam motion I do know people that have and they were very happy.
They will custom grind for your application and goals.
Old Aug 24, 2018 | 06:17 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
All my LS cams came from Futral Motorsports. They use cam motion, but have custom lobes. I have not had any issues with anything I have run to date. Do you know what cam you are looking at and what mods you will do to the LS?
Old Aug 24, 2018 | 10:35 PM
jwp2's Avatar
jwp2
Yeah...Here is the cam:
PRODUCT DESCRIPTION
Grind # Grind# XA218/345-XA222/340-12+3
Hydraulic Roller Camshaft
Mild Street Performance
Duration at .050": 218/222
112 Lobe Center Angle with a 109 Intake Centerline
Lift with 1.7 Rocker Arm Ratio: .586"/.578"
Recommended Displacement: 5.7-6.0 Liter Engines
Cylinder Heads: Cathedral Port
Recommended Compression Ratio: 9.0-10.75:1
Recommended Headers: Stock Manifolds - 1 3/4"
Recommended Stall Converter: Stock-2800
Recommended Rear Axle Ratio: Stock
adding New lifters, pushrods, and springs.
The only other real mods on the engine will be an LS6 intake, fuel rails, and injectors and mid length headers. Hoping to get between 350-400HP
Old Aug 25, 2018 | 01:34 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Cam Motion is a small cam company who grinds cams for a lot of folks in addition to their own designs. I visited there once late at night and they had just finished a pallet load of small block Ford hyd roller cams for Comp cams. They also do a lot of private label stuff for tuners and engine builders. Since they do cams for other cam companies...they have the masters for lots of other folks' lobes. The guy working there who gave me the tour had one wish...and it was it would be great to let folks know who REALLY designed the cam being sold under the tuners/builders names. He had a lot of pride in what they do and wanted the company to get credit for it.
We did have them do one for a 632" we built once.
I've used smaller companies in the past and had great luck. Engle made some great ones for me.
JIM
Old Aug 25, 2018 | 04:03 AM
terrys6t8roadster's Avatar
terrys6t8roadster
My 69 434 SBC has a custom Cam Motion solid roller cam. Engine is close to 15,000 miles and running strong. They ground the perfect cam for my engine. T
Old Sep 2, 2018 | 11:16 PM
jwp2's Avatar
jwp2
bought the cam from cam motion...will be installing it this weekend...thanks folks!
To Cam motion feedback
