Different Edelbrock Air Gap
Old Aug 27, 2018 | 01:00 PM
cv67's Avatar
cv67
St. Jude Donor '05
Makes sense lionel. Next time I have this one apart, going to:
SBC usually pop the head gasket on the rear cyls, something to look into.
The 92-96 LT1 heads use a pipe on the rear of ea cyl head has to be a reason.
Toyed with the idea of the lines from front to rear on the intake, but was that really enough or a me too thing?
Old Aug 27, 2018 | 03:59 PM
jim2527's Avatar
jim2527
Those are 'reverse' cooling: pump heads block pump.... Just wondering if that's a contributing factor or not....
Edit: LT1/4 gen II SBC has the rear of the heads connected then a pipe running to the radiator. Its a 'steam pipe' to eliminate dead areas of flow. I'd guess on a gen I a left right pipe would help to balance flow to each bank.
