Manually turning engine (over)
Old Aug 28, 2018 | 02:28 PM
kansas123's Avatar
kansas123
Default Manually turning engine (over)
I want to manually turn the engine crank while watching the distributor rotor so that I might get an idea how tight or loose the time chain might be. I saw a comment on a utube video that said something about "....you don't want to do this, the bolt is not very long and it's not a #8....", which made me think a person might break the head off the bolt. How possible is that? I don't want to move it that much, just enough. Don't really want to take the plugs out either. It's a 350 running engine, just curious about the chain. Thanks.
Old Aug 28, 2018 | 03:10 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
if the engine is not locked up (obviously yours isn't) you won't break the bolt.
Old Aug 28, 2018 | 03:28 PM
sstopczy's Avatar
sstopczy
Much easier to turn with the plugs out. I've done it by just taking a few out which helped me turn it without fear of stripping the bolt head.
Old Aug 28, 2018 | 05:27 PM
teamo's Avatar
teamo
With the plugs out you can turn the engine by hand by pulling on the accessory belts.
Old Aug 28, 2018 | 05:47 PM
kansas123's Avatar
kansas123
Thanks everybody, great suggestions to ponder.
Old Aug 28, 2018 | 06:20 PM
speedreed8's Avatar
speedreed8
You can turn the engine using a socket and breaker bar on the alternator pulley nut Just squeeze the belt together a little and turn
Old Aug 28, 2018 | 06:48 PM
'75's Avatar
'75
This is by far the easiest!
Old Aug 28, 2018 | 10:15 PM
kansas123's Avatar
kansas123
Well for Pete's sake.....thanks....
Old Aug 29, 2018 | 05:24 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
get a cheap remote starter that clips onto the starter solenoid. you can make one cheap as well. You'll use it more than you think and they are handy for getting the motor turned over without any hassle
To Manually turning engine (over)
