Gas Tank Whoosh?
Old Oct 24, 2002 | 02:26 AM
cookin1979's Avatar
cookin1979
Default Gas Tank Whoosh?
Everytime I take the gas cap off to fuel up, I get this tremendous sucking sound from my fuel tank. It makes no difference if the tank is empty or 3/4 full. What causes this? Is this normal? What's the advantages of a vented cap?
Old Oct 24, 2002 | 07:40 AM
thamzid's Avatar
thamzid
Default Re: Gas Tank Whoosh? (cookin1979)
Sounds like the Vented Cap is no longer Venting. Make sure it is not plugged.
Old Oct 24, 2002 | 11:41 AM
Brettmc's Avatar
Brettmc
Default Re: Gas Tank Whoosh? (thamzid)
Do all caps need to be vented? The old gas cap on my 74 said "vented" on it (also had no gasket on it). The one I put on last night (from Zip) is unvented. Haven't had a chance to drive with the new cap on it. Is my gas tank going to implode??? :eek: :eek: :eek:
Old Oct 24, 2002 | 11:47 AM
81Vette_by_eric's Avatar
81Vette_by_eric
my beretta used to do that. mostly when i was running on fumes in summer. haven't heard it with the Vette yet. I agree with the need for a vented plug. I don't think the tank will implode, but it can't be good. I wonder, could that effect the fuel be pumped out by lowering the pumped pressure?
Old Oct 24, 2002 | 02:03 PM
Brettmc's Avatar
Brettmc
Default Re: Gas Tank Whoosh? (81Vette_by_eric)
That's what I'm wondering, if a vacuum will form in the tank, eventually choking down the fuel pump.
Old Oct 24, 2002 | 02:29 PM
Bobchad's Avatar
Bobchad
Default Re: Gas Tank Whoosh? (Brettmc)
Do you still have your vapor cannister and is the line running from the tank to it clear.
To Gas Tank Whoosh?
