sbc 400 help
Old Aug 28, 2018 | 10:31 PM
Steven24f's Avatar
Steven24f
Default sbc 400 help
I am currently rebuilding a 400 sbc to a 406 and was looking at the options I have and the one big think that confuses me is the rod length some kits offer 5.7in rods which are closest to the factory size but most include a 6in rod. Now I've heard that the 6in rods can cause a clearance issue with certain cams and would like to hear how did you guys rebuild yours and what cam specs did you use also if clearance was ever an issue.
Old Aug 29, 2018 | 03:39 AM
terrys6t8roadster's Avatar
terrys6t8roadster
434 SBC with 6 inch rods in my 9-car. I have put together a lot of SBCs myself, but my last two engines I had my engine builder put together my short blocks, [not cheap but in my opinion worth every dollar]. Using a small base circle cam. As far as cam specs go, match your cam to your heads. My cam was a custom grind from Cam Motion to match my Dart heads. For the right cam call a couple of cam grinders they will ask all the right questions about your goals with the car, about the car and your engine build. I run solid roller cams, most folks use hydraulic roller for street and track use. T
Old Aug 29, 2018 | 07:24 AM
L88Plus's Avatar
L88Plus
Use Scat "ProComp" rods, they're profiled for better clearance on cams and pan rails. And they're strong as hell.
Old Aug 29, 2018 | 09:04 AM
Steven24f's Avatar
Steven24f
thank you will definitely look for a cam grinder near me the smaller base circle cam does make sense
Old Aug 29, 2018 | 09:08 AM
Steven24f's Avatar
Steven24f
I was looking to use the scat Pro-Stock rods did not know that there would be a clearing difference between these and the Pro-Comp
Old Aug 29, 2018 | 09:18 AM
gkull's Avatar
gkull
It has nothing to do with the rod length. The beam and crank end of the rod cause clearance problems. With the cam
you want the biggest base circle on the cam that will work I have two roller cam motors with. .950 base circle
Old Aug 29, 2018 | 06:51 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I built my 406 with a flat tappet cam and 5.700 Eagle SIR rods......they are profiled like the SCAT rods for clearance. As far as the 5.700 vs. 6.000 debate.......a lot of us are not running sustained high RPM under load so it is unnecessary to me......
If building a max effort deal.....yes...the 6.00 rod is standard issue.
A 406 with a 5.700 rod has a very similar rod ratio as a 6.00 rod 434.........keep that in mind.
Have fun
Jebby
Old Aug 29, 2018 | 07:21 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
If you use "stroker" rods, they have more clearance to the cam lobes and to the block skirts; also I-beam rods generally have more clearance than the H-beam rods. Cam wise, greater overlap (the lower lobe separation numbers) will have reduced cam clearance than wider lsa's. In any event, the engine builder must check this. My last 406 used a standard base circle roller cam and cleared fine with the SCAT Pro-Series I-beam rods.
More considerations about rod length... 5.7" rods generally require a non-neutral harmonic balancer and a non-neutral balance flywheel or flex plate. On the other hand, 6.0" rods in crankshaft kits often combine to permit neutral balance damper and flywheel/flexplate.
Old Aug 30, 2018 | 01:09 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
6" rods allow for a lighter piston...which is good. Remember...the stock 400 used 5.565" rods originally.
If you can get rods to clear with better profiling...try not to do the reduced base circle deal. I did a 400 using a Dart block and had no issues with regular cam profile.
JIM
Old Aug 30, 2018 | 08:53 AM
Steven24f's Avatar
Steven24f
JIM
yea wasn't to happy about having to go with a reduced base circle cam so talked to a couple of machine shops and two of them gave me the same option of grinding down all 8 rods equally to give the clearance for any cam. they both said they've done it before and on a 400 with no issue
Old Aug 30, 2018 | 12:54 PM
427Hotrod's Avatar
427Hotrod
You can get the rods that are already shaped correctly...but in reality it's only small amount of grinding.
JIM
To sbc 400 help
