But the wires are right !!!!!
Old Aug 29, 2018 | 12:25 PM
yelo80vette's Avatar
yelo80vette
Default But the wires are right !!!!!
About 3 weeks ago I decided to put new plugs and wires in my 1980.
Now it sputters and backfires to the point it can't be driven.
It's acting like one of the plug wires in on the wrong plug.
However, it's been checked and rechecked 5 times. The plugs
have been repulled to check the gap which is perfect.
The wires are on the plugs and the distributor cap tight.
Why why why is it still running this way ??? ! ! !
Old Aug 29, 2018 | 12:33 PM
A88FXRS's Avatar
A88FXRS
wires out of sequence on the cap !!!! 1 8 4 3 6 5 7 2
Old Aug 29, 2018 | 12:37 PM
yelo80vette
1 8 4 3 6 5 7 2. Yep. That's how it's wired.
Old Aug 29, 2018 | 01:05 PM
bradleyb66's Avatar
bradleyb66
Did you remove and replace one wire at a time, or pull them all off and then re-install from scratch? If the latter, then you might be 'one off' on your distributor cap starting point for cylinder #1??
Old Aug 29, 2018 | 01:08 PM
yelo80vette
Oh yea. Always replace them one at a time. And like I said, I literally rechecked it 5 times.
sstonebreaker's Avatar
sstonebreaker
Did you replace the coil wire?
Old Aug 29, 2018 | 01:19 PM
yelo80vette
Yep, sure did.
Old Aug 29, 2018 | 01:42 PM
sstonebreaker
Have you put a timing light on it to make sure you didn't twist the distributor?
Are all the connections tight? Used dielectric grease?
Replaced the coil?
Tried putting the old coil wire back on to see if the new one's defective?
Checked the resistance on all the plug wires?
Done maintenance on the distributor?
Old Aug 29, 2018 | 03:53 PM
bradleyb66's Avatar
bradleyb66
Originally Posted by yelo80vette
Yep, sure did.
Don't you have an HEI distributor? If so, which 'coil wire' did you replace? Other than the coil wire, I agree with SStonebreaker's list of other things to check, and also try replacing the dist cap - it's possible that something else just happened to go bad while you had the hood up...
Oh - one more thing. If you had the dist cap off, check that it's seated properly.
Old Aug 29, 2018 | 03:54 PM
derekderek's Avatar
derekderek
Put all the old wires back. Run good? Send the new ones back.
Old Aug 29, 2018 | 04:07 PM
BlackC3vette's Avatar
BlackC3vette
HeadsU.P.'s Avatar
HeadsU.P.
Don't let wire numbers 5 & 7 anywhere near each other. Separate them with your wire looms or sometimes they will crossfire.
Old Aug 29, 2018 | 08:19 PM
Milan454's Avatar
Milan454
Might ground one cylinder at a time with a test light probe and identify the culprit cylinder. Then swap plug and wire to adjacent cylinder and retest.
Old Aug 29, 2018 | 08:33 PM
sstonebreaker
Good idea. Didn't think of that one.
Old Aug 29, 2018 | 10:59 PM
naramlee's Avatar
naramlee
check for:
a broken spark plug
heat range
spark gap
plug brand
Old Aug 29, 2018 | 11:10 PM
sambrand's Avatar
sambrand
if you pulled all the wires and replaced them at the same time theres a good chance you reversed 1 and 6, dizzy can be installed either way and only the rotor pointing to tdc is at number 1, or its 180 degrees off, ive seen this very exact same issue a dozen times
Old Aug 30, 2018 | 10:37 AM
yelo80vette
Wow. I had no idea. Thanks for the info.
To But the wires are right !!!!!
Old Aug 30, 2018 | 11:47 AM
cv67's Avatar
cv67
St. Jude Donor '05
Cant tell you how many times I had 5 and 7 to the wrong plug after checking it again and again.
Curious to see if you didnt crack a plug when torquing it down
Old Aug 30, 2018 | 04:14 PM
80-Vette's Avatar
80-Vette
Been there done that.
Old Oct 22, 2018 | 01:45 PM
Tazz 1's Avatar
Tazz 1
Cruising
Default Spark Plugs
Did you by chance drop any of your plugs on the ground, I dropped a plug one time and it cracked, car ran like crap. Took me forever to find out what was wrong.
