Reinstall rear spring
Old Sep 2, 2018 | 08:46 PM
croaker's Avatar
croaker
Default Reinstall rear spring
Hey guys anyone who has reinstalled the rear spring notice that area between dif and spring? I haven't put weight on the car yet
Old Sep 2, 2018 | 10:50 PM
revitup's Avatar
revitup
So you haven't fully torqued the four bolts then, right?
Old Sep 2, 2018 | 10:51 PM
croaker's Avatar
croaker
That's right but they are pretty snug.It looks like it's in there straight just that gap.
Old Sep 2, 2018 | 10:54 PM
croaker's Avatar
croaker
I'll probably just drop it and double check the locator maybe clean it up. I just thought someone else might have noticed this while doing theirs. On my old back strugglin
Old Sep 2, 2018 | 11:11 PM
GTR1999's Avatar
GTR1999
What is the thread size of the 4 bolts? 7/16 or 9/16
Old Sep 3, 2018 | 08:16 AM
Tim69L46's Avatar
Tim69L46
There shouldn't be a gap Don't try to tighten it further to force it in you may break an ear on the cover. It should pull tight if you are replacing a spring with the same number of leaves as removed. The length of the bolt only matters if you had a 9 leaf and are installing a 7 leaf spring. You will need the shorter bolts. If you are replacing a 9 leaf with a 9 bolts should be fine. I suspect it's the center bolt. It may have been shipped with a generic one or the wrong size that needs to be replaced. Make sure it's currently aligned with the hole. If it is drop the spring and compare the height of the head and it's diameter to the one in the spring you removed. Also check the hole in the differential housing where it nests to make sure it's clean and free of damage. If you need a different bolt check the new one you get in the differential before installing it in the spring to make sure it fits. It's easier and lighter without the spring and will save some grief if it isn't correct
Old Sep 3, 2018 | 12:41 PM
croaker's Avatar
croaker
It's my original spring I just cleaned it up a bit and painted. I didn't disassemble it
Old Sep 3, 2018 | 01:35 PM
revitup's Avatar
revitup
I'd just double check that the center bolt head is engaged in the differential recess and put the vehicle weight on it. See what it looks like. The gap should close up.
Old Sep 3, 2018 | 08:11 PM
croaker's Avatar
croaker
Gary they look like 9/16 and are original to the car
Old Sep 3, 2018 | 11:04 PM
GTR1999's Avatar
GTR1999
The reason I asked is the spring does not appear to fit the cover correctly but I can't clearly see it. The 63-77 covers have flat surfaces where the spring bolts up and uses 9/16 bolts. The 78-79 springs changed and so did the covers. There is a cast in pad and the bolts were 7/16. Was the rear cover replaced?
Old Sep 4, 2018 | 02:36 AM
croaker's Avatar
croaker
Not to my knowledge.I work off today so I'll be back working on it. If that Hurricane doesn't swing our way
Old Sep 4, 2018 | 08:38 PM
1moore522's Avatar
1moore522
That's because you painted it. They are not painted from the factory. Scrape the paint off the edges of the springs and it will be snug but it will fit.
Old Sep 5, 2018 | 10:40 PM
davidchristopher's Avatar
davidchristopher
Look at how much he's off. No way there's 1/8" of paint on there...
Old Sep 5, 2018 | 10:52 PM
kansas123's Avatar
kansas123
He might mean scrape paint from here on this edge of the leafs, or is that, leaves...
Old Sep 6, 2018 | 12:11 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Croaker,
I blew up your picture and ran it through a filter to lighten it up... it doesn't appear to be an original spring. The original Eaton springs would have been square on the edges with a flip up on the end. However, I don't think that is your issue either...
Possibly is the liner not trimmed enough and causing it to hit. When you install new liners you have to trim off the H section where the rear goes into the cover.
Also please note that you do not torque this while it's in the air... you snug the bolts... lower the car, roll it up and back and then tighten the bolts.
Willcox
Old Sep 8, 2018 | 09:35 PM
GTR1999's Avatar
GTR1999
Any news on this?
Old Sep 9, 2018 | 08:33 AM
croaker's Avatar
croaker
That’s where I’m at Wilcox just snug. Those are same liners I found in there. Gary all I’ve done is swapped my u- joints out. Water Heater trumped the car.
To Reinstall rear spring
Old Sep 9, 2018 | 07:40 PM
Duke94's Avatar
Duke94
I just took my spring off today (79') and as I loosened the 4 bolts the spring did just what you show in the picture. Gaps at the corners. As Wilcox said, when reinstalling it. snug them and tighten after it's on the ground.
Old Sep 9, 2018 | 07:54 PM
0Willcox Corvette
Former Vendor
I'm confused then.. same liners and you didn't take the spring apart.... You might look and see if the liners are off set just a bit and possibly flip the spring 180.... I'm not sure.... but possibly whoever put the last spring in may have the liners tossed to one side and not the other. I hate the simple repairs that go haywire... We have one in our shop right now that is just mind boggling..... so you're not alone.
Ernie
Old Sep 10, 2018 | 01:19 AM
naramlee's Avatar
naramlee
Ernie
I would like to hear more E :P
