engine paint ?
Old Oct 24, 2002 | 06:31 PM
kingdavidrules's Avatar
kingdavidrules
Default engine paint ?
just wanted to know if there was a primer i could use before repainting my engine ?
Old Oct 24, 2002 | 07:58 PM
72GACRZR's Avatar
72GACRZR
Default Re: engine paint ? (kingdavidrules)
I am not the expert, but I would think you don't want to use any. The typical engine paint works well and I don't think you want too thick a coat on there to hold in heat. My .01cents.
Old Oct 24, 2002 | 09:08 PM
Road Racer's Avatar
Road Racer
Default Re: engine paint ? (72GACRZR)
I would not use any primer. As far as paint any spray paint is good, it can be engine paint or not. The only paint that is no good is silver because it turns brown with heat. From my experience even body paint is ok to use. I have a friend who paints his engine the same color as the body using the same paint. Years later the paint is still like new. :hat
Old Oct 24, 2002 | 10:15 PM
ROD NOCK's Avatar
ROD NOCK
If you have bare metal areas, it's a good thing to use a prime coat to provide better adhesion for the paint.
This is what I use for alot of refinishing: http://store.summitracing.com/defaul...Easp%3Fs%3D180
Old Oct 25, 2002 | 03:52 AM
paintdaddy's Avatar
paintdaddy
Default Re: engine paint ? (ROD NOCK)
I have never used any because if you are going to put a high heat paint on an engine ,then you probably need a high heat primer and I have never seen one.I have heard of people using body paint on their engines and I have also heard of problems with that due to catalyzed products not letting the heat escape. :yesnod: :seeya
Old Oct 25, 2002 | 05:12 AM
tippi58's Avatar
tippi58
No primer needed as you need a thinnish coat due to the heat. Make sure surface is clean and no oil or debris and lightly spray a good quality heat resistant paint.
Dont go tooooo thick with one coat as it will crack and peel reaaal fast..
:cool: :cool: :cool:
Old Oct 25, 2002 | 10:05 AM
78pace's Avatar
78pace
Default Re: engine paint ? (tippi58)
por-15 sells a kit everything you need. they have about 25 different colors for the top coat. check out their site search on por-15. 40.00 bucks i got one but havent used it yet. motor is in the cellar being cleaned up.
Old Oct 25, 2002 | 11:32 AM
ROD NOCK's Avatar
ROD NOCK
Default Re: engine paint ? (paintdaddy)
F.Y.I.- VHT makes such a primer, works good! :chevy
Old Oct 25, 2002 | 11:35 AM
Maco Shark's Avatar
Maco Shark
I always use a primer, I believe that it makes the engine look better.
I use Plastikote engine primer. Never any problems, and looks and works great.
Old Oct 25, 2002 | 01:57 PM
kingdavidrules
Dont go tooooo thick with one coat as it will crack and peel reaaal fast.. thats the problem i have had in the past and the reason i was interested in a primer . with such primers do i really have to concern myself with the heat not being able to escape the engine ?
Old Oct 25, 2002 | 01:58 PM
kingdavidrules
Default Re: engine paint ? (Maco Shark)
i cant seem to find them anywhere , just had my guy at pep boys order me some .
To engine paint ?
