since the bkr4e-11 are one step hotter than the fr5, would they be more performance oriented for aluminium heads?
colder plugs are more performance oriented.
Colder=less likely to detonate due to high combustion temps.
Hotter=more likely to detonate under high performance operations but self clean better under low performance operations.
well most of my driving will be in city, not much highway use at all. That being said the motor is fairly high performance with brodix aluminum heads, rpm air gap, Holley 770, 1.6 roller rockers , xe274h cam. Would I be better off with a hotter or colder plug
I would start with a 5 heat level plug. That is a pretty good all around heat range. You know your gonna get on it sometimes. If your plugs get all dirty and your jetting is good then you might try a hotter plug.
Higher compression may want a cooler plug as well. Say 11.0:1 or more.
I run 10.6:1 and use the FR5 NGK without problems.
fr5 is heat range 5 so that means it runs 1 step cooler than the fr4 which is heat range 4? I’m pretty sure my compression ratio is 10 maximum, probably between 9.5-10
So I took a look and the plugs I have now are accel 576s which are heat range 6. Based on my build would you go with the al3924 or fr4 which are heat range 4 or the fr5 which is heat range 5?
I run the champions in y 383 with RHS PRo-Action heads and have no problems with them. They fire fine and burn clean...in fact I'm still running the same set from when the motor was built in 2015.
My theory is that for a given heat range the Champion plugs err on the cold side so In my experience tended to foul easier if you were putting around at low revs. A lot has to do with the fuel air ratio you are running, if your engine mixture is set up on the rich side I found Champions would foul and misfire before an equivalent NGK. Your risk though should you decide to fit a hotter heat range plug than say the car manufacturer or cylinder head manufacturer recommends. When I was setting up my new carb, it came out of the box stinky rich and during the process of getting things right the plugs would foul NGK FR5 or Champion RC12YC (Dart heads) and once fouled it was game over, they just wouldn't clear. I'm thinking our poor fuel quality here doesn't help either.
