Willcox
Old Sep 26, 2018 | 01:03 AM
JR333's Avatar
JR333
Default Willcox
I bought from Willcox a stainless steel emergency brake hardware kit. I just installed one side tonight and it seems the retainer pins are too long. These pins are a 3 piece assembly consisting of the pin, spring and retainer cup, one for each shoe. The problem is that the cup is too high, I think because the pin is too long and when I spin the hub the back side of the wheel studs click against the top of the retainer cup. I also bought the backing shields for both sides so it's not my old parts causing the problem.
You must have run across this problem before so what's the fix ?
Regards
Jack
Old Sep 26, 2018 | 01:28 AM
riverracer au's Avatar
riverracer au
try posting in here in this thread, Mr Willcox checks in all the time.
https://www.corvetteforum.com/forums...l-respond.html
Old Sep 29, 2018 | 12:33 PM
JR333's Avatar
JR333
Thank you....that worked.
To Willcox
