Cylinder head question/ Desktop Dyno
Old Oct 25, 2002 | 01:55 PM
jerryjfunk's Avatar
jerryjfunk
Default Cylinder head question/ Desktop Dyno
What is intake/exhaust valve pressure drop? In desktop dyno, under cylinder head, custom port flow, you have to fill that in. It normally says 1.0 in H20.
Thanks,
Jerry
Old Oct 25, 2002 | 04:19 PM
gkull's Avatar
gkull
Default Re: Cylinder head question/ Desktop Dyno (jerryjfunk)
Jerry, When a shop flow rates a given head it is usually rated at 28 inches of vacuum. So it's how many CFM of air a port can flow while influenced by a vacuum source. Some places also use 25 inches of vacuum so you have to be careful when your looking at a heads ability in CFM of air flow
Old Oct 25, 2002 | 07:30 PM
jerryjfunk's Avatar
jerryjfunk
Default Re: Cylinder head question/ Desktop Dyno (gkull)
So, the more influence vaccum has, the less power they end up making?
Thanks for the help!
Jerry
To Cylinder head question/ Desktop Dyno
