The plug at the (not actually a proportioning valve but every one calls it that anyway) switch acts as a ground. If your brake light lights on your dash, that may be why it was disconnected. Please fix the root cause of the issue, not just the symptom.
100% correct , it is just a pressure differential switch. Simple spool shifts with system pressure loss on one side or the other.
The 73-75 L82 vettes had a working cowl door hood, that might be the connector from the switch under the gas pedal. There would be a brown wire going down the hood up to the door. I had an original 75 L82 4 speed coupe but it's been a long time and it's long gone now.
I have a 75 L82 it’s hanging on mine too the alarm is switch is long gone. On another 75 yellow and brown goes below windshield washer reservoir. I’ll try to look it over a little closer tomorrow.
