Trying to dial in the front hub rotors. All new bearings, seals, and rotors. I put a dial gauge on the rotor and I am getting about .025 runout. I moved the rotor over one lug at a time and it didn't correct it. I tried the other rotor that I bought and it seems to be the same so I believe that it is probably the hub. The other hub isn't ready yet because I ruined the seal so I have to pick up another one before trying the other side. I have two other hubs that I could restore and install new bearings. Should I go that route or try to shim what I have?
Check the end play on the wheel bearings too- and sometimes you have to use shims to get the runout dialed in. Hobby Lobby sells brass sheets that make dandy shim stock. And cheap..
Make sure your hub mating surface is perfectly flat. My rear hubs had gouges and ridges on the mating surface which caused similar run out. I used a flat file to level the surface. I got .001" steel arbor shims from Grainger.
I tried the other hub on the spindle and the runout was .004 so it looks like it is an issue with the hub mating surface. I have another used hub that I just cleaned up and painted. I'm going to try that one and see what I come up with.
I've been working on other things and have returned to finish the front suspension and brakes. The run out is still a problem on one side. I have .015 run out. I bought some .010 sheets of brass stock at the hardware store. I cut a section of sheet and put it under the low side (0 on the dial indicator). I expected to find .005 remaining on the high side but it was .008. I tried a piece of .005 shim and put it on top of the .010 expecting the run out to drop to 0 but it actually increased back to .015. I don't seem to be able to get more than a correction down to about .008. I've tried indexing the rotor with no improvement. Maybe it's time to replace that hub with a new one?
If you look at CraigH ( post #414 page 21) he checked runout from the back of the rotor not the front (I have the same issue as you and was going to figure it out in the future )maybe this is the answer ? I've bought a few rebuilt rotors and I'm thinking I may just buy new ones, of course not sure just yet. Prices have come down on them though.
Here's a link: https://www.corvetteforum.com/forums...post1583201124
