69 Fuse Block Installation Help
Old Oct 7, 2018 | 04:30 PM
sjstub's Avatar
sjstub
Life Member
Default 69 Fuse Block Installation Help
I'm doing an interior "clean-up" to replace wiring, led bulbs, & many other electrical components. Took out the Tach/Spedo dash, center console, gauges. I'm not replacing the fuse block or any wiring harnesses, just cleaning it up. I disconnected the 3 body parts of the fuse block and am now ready to install it. The engine is in, so I've got to get at the engine-side from down below. Any tips, suggestions, or advice would be greatly appreciated.
Old Oct 7, 2018 | 04:54 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Remove the driver's side splash shield and you may get a little room. The vacuum supply tank makes for a tight fit where you want to go.
Old Oct 7, 2018 | 08:18 PM
sjstub's Avatar
sjstub
Life Member
Thanks, I did that. Still a tight fit, but I guess thats a "welcome" to the world of classic Corvettes!
To 69 Fuse Block Installation Help
