that "4 barrel"sound
Old Oct 26, 2002 | 07:13 PM
wadey's Avatar
wadey
Default that "4 barrel"sound
Replaced my q-jet a few years ago with a holley and am very pleased
except i seemed to have lost that nice sound i had with the q-jet when i
opened the secondaries. Wondering if this is the nature of the beast or
possibly a problem with the secondaries not opening completely? Should
i have the same sound regardless of the carb? Carb is a #3310 vac. sec.
duel feed.
thanx wade
Old Oct 26, 2002 | 07:20 PM
Aaron-74's Avatar
Aaron-74
Default Re: that "4 barrel"sound (wadey)
Compare the size of the Holley butterflies..and the Q-jet sizes. You'll see the Q-jet has too tiny in the front, and two HUGE on the rear. And then Holley has 4 of the same size.
Old Oct 26, 2002 | 07:38 PM
Jvette73's Avatar
Jvette73
Default Re: that "4 barrel"sound (Aaron-74)
With the vac sec 750 it will only open up what you need. Since the primaries on the 750 are larger than that on the Qjet, more is served with the primaries. since the vac secondaries will only supply whats needed, the arent opening at an abrupt rate which gives you that "bog" sound yur speakin of. another reason the Qjet, which can be a very good carb if set up right, has been dubbed>"quadrabog"
You could experiment with some lighter secondarie diaphram springs that will bring the 750 in sooner. Too much too soon will give you that "bog"
What size is yur engine? My 350 pulls hard to 5500rpm with a meager Holley 600.
Old Oct 27, 2002 | 11:49 AM
Chuck Harmon's Avatar
Chuck Harmon
Replaced my q-jet a few years ago with a holley and am very pleased except i seemed to have lost that nice sound i had with the q-jet when i opened the secondaries...
Wadey,
I hear you! The sound you heard and now miss was a musical tone made by the the large difference between the primary and secondary bores. Think of a small horn playing next to a large horn, two notes being played simultaneously.
Chuck
Old Oct 27, 2002 | 12:14 PM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
I recently replaced my carb. That sound is the reason I stuck with a [new Edelbrock] Quadrajet.
There just aint nothin like that sound. :cheers:
P.S. We won't talk about how much extra it cost to keep that sound. :lol:
Old Oct 27, 2002 | 11:50 PM
feb18blacksunday's Avatar
feb18blacksunday
From: Boone NC home of 3peat National Champs ASU Mountaineers
St. Jude Contributor
Default Re: that "4 barrel"sound (gb4622)
Music to my ears. :cool:
Old Oct 28, 2002 | 12:55 AM
Schmucker's Avatar
Schmucker
I haven't hit the go-fast peddle enough to go from hanging on tight to listening to the car.
To that "4 barrel"sound
