454 crate motor
Old Oct 26, 2002 | 08:13 PM
Obdoc's Avatar
Obdoc
Default 454 crate motor
Does anyone have the 454 HO crate motor installed? I am considering swapping my 350 for the crate 454 but I would really like to know how it sounds. Does it have a rough idle or is it too smooth? I like a nice rough, lopey idle. The 350 I have now has a .510" lift, 245 duration cam and has a great sound at idle. Thanks for any info. :flag
Old Oct 26, 2002 | 08:23 PM
GDaina's Avatar
GDaina
Default Re: 454 crate motor (Obdoc)
sound depends on your exhaust system and cam.....the big block's sound just ooozes horsepower
Old Oct 27, 2002 | 08:08 AM
MassVette's Avatar
MassVette
I put the 454HO in the '67 (same frame as a C-3). It's a great motor! Starts very well, and doesn't ever overheat. It idles around 800 rpm's, and lopes nicely with the side pipes. Of course it DOES idle smoother than the ZZ/502 in the '79!
:yesnod: :chevy :chevy :yesnod:
P.S.
Big Blocks sound NOTHING like small blocks........Big Blocks scare old women and children!
:lol: :lol:
Old Oct 27, 2002 | 08:28 AM
Road Racer's Avatar
Road Racer
Default Re: 454 crate motor (MassVette)
MassVette, What beautiful cars! Do you belong to any local clubs? I would love to see them in person. :cool:
Old Oct 27, 2002 | 11:09 AM
Obdoc's Avatar
Obdoc
Thanks guys! I think the 454 crate is the motor for me. :cheers:
Old Oct 31, 2002 | 12:41 AM
obdoc_brother's Avatar
obdoc_brother
just buy the damn motor my brother!!!! ;)
Old Oct 31, 2002 | 10:03 AM
Flareside's Avatar
Flareside
IMO, the 454 with it's 210 or so degree cam will idle WAY smoother than a small block with a 245 degree cam. 35 degrees less duration and 100 extra cubes will make a big difference. If you want to approximate the idle of your small block, you'll need a much bigger cam. Just swap it!
My 427 currently has a cam similar to the 210 in the crate 454, and it's very smooth. Too smooth for me.
-Joe
Old Oct 31, 2002 | 12:20 PM
Lasse's Avatar
Lasse
Default Re: 454 crate motor (Flareside)
I have also checked the 454 crate engine from GM.
I think the cam will sound to smooth, in my taste. But the reliability can't be beaten.
If you want to change cam, you must go with the same lift due to the net-lash system. If you also change the lift: rollerlifters, pushrods, rockers and studs must be replaced. Check the latest numbers of Chevy HP magazine.
[Modified by Lasse, 5:24 PM 10/31/2002]
Old Oct 31, 2002 | 12:24 PM
ORVette's Avatar
ORVette
I have a 454HO crate that is waiting to go in my '73. I also obtained a new ZZ502 camshaft. The guy I got my motor from works for a shop in Dallas that assembles the 454HO for GM, and he said the ZZ cam is an easy swap, and works with all the stock 454HO valvetrain stuff (ie: the net lash rockers). The ZZ specs are 224/234dur.-.527/.544lift-110lobe sep. I don't know the intake centerline, but I think it is 106. May give up a little bottom end over the stock cam, but I think this thing may have a little to spare in the name of a way cool idle. Wish I could tell you how it sounds! Soon, I hope.
Old Oct 31, 2002 | 12:50 PM
woodenichols's Avatar
woodenichols
Default Re: 454 crate motor (ORVette)
I love my 454HO. Was a little disappointed with the sound at idle but the car pulls hard and runs great. Best thing I ever did! :cheers:
Steve
To 454 crate motor
